Calibrating C300 Monitor to TVlogic at DVinfo.net
Old August 26th, 2013, 09:30 AM   #1
What would be the steps to match (as close as possible) for production work - C300's Monitor to output on TVlogic5.6 and an Alphatron EVF. Since C300 Monitor has no means to calibrate one needs to match the TVlogic & Alphatron to that.
Roger Pinto is offline   Reply With Quote
Old September 1st, 2013, 02:32 PM   #2
Re: Calibrating C300 Monitor to TVlogic
Send out color bars from the camera and calibrate each monitor separately using brightness and contrast settings so the color bars are looking correct. If you don't have the manuals you should be able to find calibration instructions online.
The TV Logics always look misleadingly good. I don't trust their color.
John Gardiner is offline   Reply With Quote
Old September 2nd, 2013, 11:48 AM   #3
Color calibration is more than just playing with Brightness & Contrast. One also needs to check thru Blue Only modes etc, I desired to know more on subject so as to bring TVlogic as close as possible to LCD of C300 for field use. Of cource it wont be replacing a field production monitor but yes the better matching is best !
