Monitor Lock screw stuck, Can't remove from Handle at DVinfo.net
Old February 3rd, 2013, 08:20 PM   #1
Hey Guys,
Anybody ever have their monitor lock screw turned too tight, and now they can't get it off the handle? Mine is currently stuck to the handle, and I can't seem to turn the lock screw at all, doesn't budge. Any idea on how to get the monitor off? Thanks guys.
Glen
Production Website: www.moonliteproductions.com
Portfolio: www.glenchua.com
Glen Chua is offline   Reply With Quote
Old February 3rd, 2013, 10:14 PM   #2
Re: Monitor Lock screw stuck, Can't remove from Handle
It happens to me on a regularly basis even though I'm careful not to tighten it too much.
Have now invested in a big pair of pliers so I can very carefully loosen it.
But would welcome a better approach.
Simon Thewlis is offline   Reply With Quote
Old February 4th, 2013, 12:35 AM   #3
I used a pair of plyers with a rubber piece wrapped around it, still couldn't get it off. Even bent some of the plastic already.
Old February 4th, 2013, 04:00 AM   #4
In this order...Tapping, Lubricant spray, heat (with a torch). Heat almost always works, but it's the most dangerous. Get professional help, if possible.
Old February 4th, 2013, 10:04 AM   #5
I had the C300 LCD monitor stuck after a very long bumpy ride. I had to go back to the room in the night and use a rough cloth for grip and then remove the monitor after a bit of struggle. At times when I don't tighten the monitor it comes off the handle. I thought I was pretty abusive with my equipment and pushing it to the limits and such stuff is kind of acceptable. So I am surprised to hear that others have had such an experience.
Wild Tiger Productions
http://www.indiawilds.com/about.htm
Sabyasachi Patra is offline   Reply With Quote
Old February 4th, 2013, 12:15 PM   #6
This all sounds like the start of a great script to a short move.
EX1 x2, C100 --> FCPX & PPro6
Matt Davis is offline   Reply
