Custom picture to match C100 and C300 at DVinfo.net
Old December 2nd, 2012, 06:14 PM   #1
I've been working on setting up custom picture files to make the C100 and C300 match. The standard profiles do not produce matching colours so they had to be matched by adjusting the custom picture settings. I have supplied files for a baked in CINE style as well as a set that use Canon Log.
more info here...
Canon C300 & C100 matching custom picture files | Paul Joy – Freelance Filmmaker
Blog: www.pauljoy.com
Paul Joy is offline   Reply With Quote
Old December 2nd, 2012, 08:37 PM   #2
Re: Custom picture to match C100 and C300
I dont know why but when I go to my card I get "Private" as the my only option and I open the folder and only have AVCHD am I doing something wrong. My card has been initialized.
www.nickelsvision.com
Canon C100, Canon 5D MK iii, Canon 5D MK ii (Magic Lantern), Panasonic GF1 (Hacked)
Peter Chaney is offline   Reply With Quote
Old December 2nd, 2012, 08:47 PM   #3
Hi Peter.
If you go to the Custom Picture menu and transfer one of the standard profiles to the SD card it should create the required folder structure on the SD card.
regards
Paul.
Old December 2nd, 2012, 09:03 PM   #4
Well I feel dumb. Thank you for these files Paul.
1 last question for you. Do you know if C300 files would work on a C100?
Old December 2nd, 2012, 09:38 PM   #5
I've not tried placing a C300 file in the C100, but even if they did work the colours would be different because manually setting the same values doesn't produce the same results.
That's why I have made a different set for the C100 and the C300 :)
