Canon C300 + 40mm pancake Mfr# 6310B002 at DVinfo.net
Old July 18th, 2012, 04:59 PM   #1
Guest
Posts: n/a
Auto focus doesn't work... yet?
pancake | Flickr - Photo Sharing!
Old July 19th, 2012, 06:26 AM   #2
Re: Canon C300 + 40mm pancake Mfr# 6310B002
Hi Philip,
Great photo!
Looks like a fancy lens cap!
Bit fiddly to focus manually on a C300 so autofocus would be a great addition to the firmware wish list.
Can't be that difficult?
Incidentally I bought the EF-S 18-135mm f/3.5-5.6 IS STM to add to my kit. It's very useful for those situations where you just need a bit more throw on your lens such as filming a meeting or group of people.
Very smooth focus, good IS and pleasing bokeh. Not quite as sharp as the 17-55mm F/2.8.
Mark Dobson is offline   Reply With Quote
Old July 19th, 2012, 05:38 PM   #3
I have to admit, the pancake on the C300 made me giggle. :)
Jon Fairhurst
Old July 20th, 2012, 02:10 AM   #4
We won't ever see proper auto-focus on the C300 as it doesn't have the necessary hardware like the XF105/305 or even the T4i/650D for using the new STM lenses.
The Canon 17-55mm F/2.8 is what I generally have on my C300 just about the only other lens I use is the 70-200mm F/2.8L IS II. I have however contemplated buying the 18-200mm f/3.5-5.6 IS for that extra reach for run'n'gun situations. For even greater reach there is the Sigma 18-250mm & the Tamron 18-270mm but I have always been so disappointed with off-brand lenses that I will probably stick to the Canon.
Old July 20th, 2012, 07:11 AM   #5
Hi Nigel,
I agree with what you say " We won't ever see proper auto-focus on the C300 as it doesn't have the necessary hardware like the XF105/305 or even the T4i/650D for using the new STM lenses"
The hardware you refer to is presumably the sensor?
The actual mechanical focus adjustment is achieved within the lens either with USM ( UltraSonic Motor ) or the new STM.(Stepping Motor Technology)
The T4i/650D has the hybrid CMOS sensor that has a phase detect capabilities built on the image sensor itself to enable it to constantly auto focus.
Now I'm not clever enough to really understand how that all works and all I would ever want would be to to electronically spot check the focus. Just like I do with my Canon 7D.
So could a firmware update enable the C300 to utilise the contrast detection autofocus method?
This is achieved by measuring contrast within a sensor field, through the lens. This method of autofocus is implemented in software.
Old July 20th, 2012, 08:00 AM   #6
I suspect that the C300 doesn't even have the hardware necessary to talk control the focus motor within the lens.
Old July 21st, 2012, 01:28 AM   #7
The C300 is able to focus a lens through the wireless controller or a Lanc controller so that end of the equation is there.
All it needs now is the firmware to be tweaked to enable the sensor to be used to measure focus . . . or not.
This is a question for someone like Alan Roberts.
Old July 21st, 2012, 07:27 AM   #8
Then how is it the WFT can pull focus?
David A. Fisher is offline   Reply With Quote
Old July 21st, 2012, 12:47 PM   #9
Of course you are absolutely correct I had forgotten that I had actually read a review of the WFT-E6 used on the C300 describing the ability to remote focus.
Old July 21st, 2012, 09:36 PM   #10
Speaking of 40mm lenses, my favourite lens on the C300:
http://www.bhphotovideo.com/c/product/534437-REG/Voigtlander_BA229DN_Ultron_40mm_f_2_0_SL_II.html
A bit pricier but a stop faster than the Canon, close focussing, wonderful build quality, tactile focus ring.
Josh Dahlberg is offline   Reply
