17-55mm Canon lens + Formatt Filters = avoid at DVinfo.net
Old May 30th, 2012, 11:36 AM   #1
Just came back from a shoot and found a lot of wide shots at 17mm with a vignette effect.
I was using a Formatt Polarising filter on the Canon lens but I suppose it could happen on any similar size filter.
I also happened to purchase some "super slim" Polarising filters from Jacobs today and they work ok at 17mm.
Syeed Ali is offline   Reply With Quote
Old May 30th, 2012, 12:45 PM   #2
Re: 17-55mm Canon lens + Formatt Filters = avoid
One option is to buy a step up ring and use oversized filters.
Jon Fairhurst
Old June 4th, 2012, 05:26 AM   #3
Telecam Films
I have bought a FORMATT ND 0.9 ND filter and it adds a very marked reddish tone that make it pretty much unsable. Formatt is no good...
Thierry Humeau, DoP
Télécam Films
www.telecamfilms.com
Thierry Humeau is offline   Reply With Quote
Old June 4th, 2012, 05:31 AM   #4
Telecam Films
Thierry Humeau, DoP
Télécam Films
Old June 27th, 2012, 07:56 AM   #5
This lens will cause vignetting on the C300 even without a filter attached, see my tests here...
Paul Joy – Freelance Filmmaker
The only reason I've kept this lens is because one of my main clients prefers a cropped look to there videos which removes the error.
Blog: www.pauljoy.com
Paul Joy is offline   Reply With Quote
Old June 27th, 2012, 08:52 AM   #6
Great looking shots Paul.
I know you have experienced vignetting with the Canon EF-S 17-55mm f/2.8 IS USM lens but I don't it's a universal problem.
I have carried tests myself and do not have any vignetting issues.
This subject was covered in a previous thread on this forum. Other C300 users experienced no vignetting issues with this lens.
http://www.dvinfo.net/forum/new-cano...7-55-c300.html
Mark Dobson is offline   Reply With Quote
Old June 28th, 2012, 04:54 PM   #7
My experience has also been that there's no vignetting with the 17-55. Seems to be a problem with some lens/camera combination, possibly caused by error in manufacture? Hard to say.
Stuart OSteen is offline   Reply With Quote
Old June 29th, 2012, 02:00 AM   #8
Fair comment, I should have said "can cause vignetting without filters". I tried two different versions of the lens with the same results on my C300. I'd be very shocked if there's variations like that in lens manufacture, even with EFs lenses. Perhaps there's differences in C300 build.
It's an odd one indeed.
Paul
Old June 29th, 2012, 03:03 AM   #9
Is there a difference in the lenses between manufacturing dates? perhaps they slightly altered the design on later models?
Steve Benjamin is offline   Reply With Quote
Old June 29th, 2012, 04:48 AM   #10
Paul
Paul, I am one of those who doesn't see vignetting so we obviously need to hold a Norfolk C300 Owners Club meet & swap our respective lenses & C300s:-)
BTW As I believe that you are an IoV member there is an area meeting at our place on 7th August so if you did want to bring your camera along...
Old June 29th, 2012, 10:46 AM   #11
Sounds like a good plan Nigel, I'll bring mine along and we'll see if we can solve it.
Old June 29th, 2012, 02:19 PM   #12
I, for one, will be very interested in what you discover.
Old July 9th, 2012, 05:16 AM   #13
I've just received a loaner C300 from Canon while mine is being repaired and my 17-55 vignettes exactly the same on that camera.
Paul.
