#91 |
Re: Reasons to go for C300 over RED Scarlet X?
I guess that I missed the moanfest...so I'm lacking some backstory here.
Said more than my share...and will retire my torch....don't really like playing RED defender, but hope that I added a little bit of additional information to the heap, for those of you trying to weigh options. It is a lot of money to spend, on either system, and the decisions are getting tougher to make. |
#92 | |
I will say that it has migrated a lot of still photographers into the video world, since they now own tools that cover both... and at the same time has moved a lot of videographers (less so) into stills.
Need to rent camera gear in Vancouver BC? Check me out at camerarentalsvancouver.com |
#93 | |
5DMkII images can be beautiful in the right conditions, but all it's issues have limited it use to a narrow range of applications and for many mean it's a non starter. It created a niche in the market that was not really there before. Specs are not secondary. Good reliable specs will tell you a lot about how a camera will actually perform in your hands as opposed to looking at videos on the web created by experts with big budgets who can tailor the shoot to get the most from the camera, avoiding areas that may cause issues. Take the 5D, independent resolution tests tell us that the resolution falls short of what most would expect from a 1080P camera. Yet on the web this is difficult to tell. If your producing web videos then that's fine, but present on a big a screen and the difference becomes much clearer. Of course one of the issues is getting reliable and meaningful specifications as opposed to the carefully selected and sometimes ambiguous manufacturer specs.
Alister Chapman, Film-Maker/Stormchaser http://www.xdcam-user.com/alisters-blog/ My XDCAM site and blog. http://www.hurricane-rig.com |
#94 |
As a complete outsider looking in ( a novice, with not a chance of owning either camera), the choice seems simpler than people are making out.
If you want a camera that will work 'out of the box', that will be much simpler to use, and will have a faster work flow without major $ investment in raw workflow then the c300 is the better choice. Run and gun? wedding/event videography? etc then I can not imagine for one second using any red camera. the reliability issue alone woryy the hell out of me! If you have more time to invest per shoot, have repeatable conditions, need higher res and absolutley must have raw, then of course the red is for you. The notion that either of these camera somehow far worse, or far better images than the other seems strange to me. You could make beautiful images with either. James |
#95 |
Actually there's a lot of sample material readily available. Scarlet output = Epic output, and there are plenty of Epic clips online coming from a wide variety of sources. The only differences between Epic and Scarlet are frame rate, 5k video, window size vs. res, etc., but the image "flavor" and quality of the two cameras are identical.
#96 | |
The C300 sensor makes many more measurements compared to the F3. Also, as I've said Canon is telling us it's noticeably better by their pricing. The only people who have compared the F3 and the C300 are Canon. Either the C300 has better IQ, or the Canon people are foolish. The trouble with specs, especially Red specs, is they don't illuminate the trade offs. What price does the Red design pay in basic IQ to do 120 fps? In power consumption? In low light capability? What's the upside of the C300's lowly specs? Are they being cheap, or making sure the 99.9% of shooting is the best it can be? I expect the clipped highlights is from pre production cameras. It's unlikely in 2011 that Canon would build a system that has a fundamental problem with gently clipping highlights. But until the F3 and the C300 are shot side-by-side we don't know. It does seems the images from each will be distinct, which is nice. I think in a few years debayered sensors will be old tech. Measuring just one color at each pixel will soon be better understood as a compromise. This may be a problem for Red, as I can't see them being ready to handle a 32mp quad 1080p sensor. I'll keep pointing out that there's likely more information off the C300 sensor (pre compression) than the 4K Scarlet. And way more than the F3. Debayering is building out a bigger file, but not adding any information, just data estimates. |
#97 |
Good point Chris. So the images will be identical? even so, friends of mine who've been renting Reds have done so primarily due to the frame rate (slowmo) options which the Scarlet doesn't do as far as i'm aware?
James Millward Yes, both will be wonderful cameras, and like you i can't currently justify buying either, however i'd take the Canon over the Scarlet any day. If i needed a Red i'd rent one, as everyone i know who needs one does (even though they can easliy afford to buy several). and i'd rent one with the resolution/frame rate options. This model seems to fall between two stools for me. I'm guessing in 18 months time there will be a lot more people kicking themselves for buying a Scarlet than there will be regretting buying a C300. The Sony F3 is a formidable camera too, so it would be a Sony or Canon decision for me. Having said that, i expect there will be amazing things done with the Scarlet by a relatively small number of people, and many others buying it without really getting anything from it they couldn't have got from Sony or Canon with a lot less hassle. Just my 2 cents. |
#98 | |
For the corporate buyer/producer, the question is if the more expensive ongoing cost of the Scarlet makes more money than the F3/C300. |
#99 |
Don
But why would anyone rent a Scarlet? There are higher end models that will only be marginally more expensive to rent and they have advantages over the Scarlet (like super high frame rates). If i didn't need those features i probably wouldn't rent a Red at all. That's what i mean about the camera falling between two stools. Rentalwise it's likely to be overpriced for what it does, So those with low budgets are likely to either go for cheaper options, while those with the cash will rent the higher spec Reds. There will also be loads on the market due to the - relatively - low cost price, so i doubt this will be much of a success for people planning to buy for rental. |
#100 |
Don, we will have to wait and see how the C300 sensor performs in the wild. But one thing to consider is that the Bayer process was in part developed to overcome issues created by the use of a 2x 2 sampled CFA (colour filter array) as used in the C300. Bayer has the big advantage in that it can help compensate for the leakage and cross colour contamination caused by the imperfect colour filters in a CFA. This compensation can dramatically improve colour fidelity. In addition assuming Canon are grouping the RGGB pixels under a single micro lens then there will be the issue of double green sensitivity compared to R and B. This may have an impact on noise as you must either reduce the green sensitivity or increase the R and B gain which will increase noise.There are pro's and cons to 2x2 CFA and Bayer. 2x2 CFA has been around since the 90's yet is rarely used. A really good example of the issues that can be caused when not using bayer is Sony's F35 which has 2 pixels for each colour in a stripe array, yet has some pretty bad aliasing artefacts.
Highlight handling will be a function of many factors including the sensor itself and the way the signal is processed and the gamma curve used. The blown out highlights could be many things, simply bad lighting, bad post production or web encoding. But it could also be poor signal processing in the camera. The whole lack of a 10 bit output does ring alarm bells as to what bit depth the DSP is working at. Ultimately we'll have to wait and see, but one thing is sure sure, with only an 8 bit output your options are more limited than with cameras with a 10 bit output. However if you don't want or need to record externally the C300 ticks many boxes.
#101 | |
(please don't tell me about the last Sundance and that 7D movie - i know) am i buying a dream - maybe, but I promise as soon as C300 is available from any rental house I will put it side by side with Scarlet X and will shoot "donkey balls" out of both of them , and 1D, and 5D, and EX1 looking for reasons to go for C300, unless of course someone else will do that before me :)
I love this place! |
#102 | ||
Additionally to Alisters comments, then it's also worth pointing out that for given sensor dimensions (let's assume 100x100) then true deBayering will squeeze a higher luminance resolution out. To a first approximation, typically about 80x80 in that case for luminance, 50x50 for chrominance. Hence the F3 sensor dimensions - such that 80% gives roughly 1920x1080. The C300 approach will give 50x50 for luminance and chrominance. So does that mean I'm saying the C300 sensor arrangement is worse? Well no, and this is where it starts to get complicated. Direct Read is far simpler to implement. And that means simpler (hence cheaper) electronics, and crucially lower power consumption. The key is in coupling it with a sensor of optimum dimensions - which the C300 does. What I also foresee is a 2nd generation camera which ADDITIONALLY will deBayer the 4k sensor (or record it RAW) to give a 4k output. (OK, it'll be only about 80% of the res, but that's what most people refer to as 4k). Or just switch it to 1080 Direct Read when that's most appropiate. The F3 sensor is less versatile - it has to be deBayered, and is then 1080, end of story. Quote:
The AF101 is the one I have the figures for, but I understand it's far from the only case of the principle. It's an acknowledged technique for video from stills cameras. (And far better than earlier techniques that skipped whole lines asymmetrically.) |
#103 | |
The fact that they are reducing a lot of the electronics and boards for the Scarlet (not to mention using sensors which didn't make the specs for the Epic) is what is currently giving me some doubts and reservations regarding the image quality and flavor of Scarlet and Epic being an exact match. As I mentioned in an earlier post, I'm a big fan of impromptu-style shooting (by someone who really knows how to set up the camera, expose properly, etc.) with minimal or no grading as being a more genuine demonstration of the camera itself. The clip below is a perfect example. It's from an Epic, where an excellent shooter was standing on the beach and was waiting for 5 minutes for the rest of the crew to show up. So he took a few minutes of impromptu footage in the meantime. Admittedly, it's slow-motion (overcranked) - which the Scarlet can't do - but if someone can post Scarlet footage which matches the flavour and quality of the actual images in this clip, I'll be 100% sold on Chris's statement. And I sincerely hope that I will be! Regarding the C300, I'm most excited by the fact that it's a 4K sensor oversampling to 1080p. I'm a big fan of oversampling and I reckon that the C300 is likely to make sensational-looking images for this reason alone. Most posters in this thread don't seem to have noticed or mentioned this fact. My initial interest in the Red One all those years ago was the fact that you could take 4K images and oversample them into a 1080p output. Well, the C300 does this without the massive files, extra computing power and extra computing time. It's a simple 50Mbps 4:2:2 onto CF cards, a battery which (per Jim Martin) runs for 7 hours and costs $150. The recent price drop of the C300 (apparently?) makes an even more compelling case. However, the final image quality and "flavor" of the C300 won't be determined by oversampling alone. How good are its electronics and how good are the gamma controls and what sort of scene files or Picture Profiles are able to be constructed? Not to mention Alister's concern that the C300's sensor array might be prone to artifacting. That's why I hope that Canon release a few C300s "into the wild" sooner rather than later. So that we can see what some good shooters can do with this camera. Without the colorists. |
#104 |
I don't see how the C300 is oversampling, even if the term is just an analogy.
#105 | ||
Canon says the DSP is working at 12 bits for the red and green and 13 bits for the green. All the non-linear processing happens at that bit depth. |
