Blu ray on DVD at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Distribution Center > Blu-Ray Authoring
Old September 7th, 2010, 02:10 AM   #1
Blu ray on DVD
I have followed numerous instructions to produce the Blu ray structure and burn to a normal DVD but as others have found , when I put the disc into my PS3 it will not auto play . I have to use the remote control and navigate to the BDMV folder and then to the STREAM folder and only then will the HD file play. I have read others having to do the same but nowhere has anyone described how to get the disc to just automatically play as when a normal dvd or bluray does when inserted. The PS3 just sees the disc as a DATA disc. If anyone has actually achieved this can they please advise where I am going wrong. Just to note : my PS3 is set to autoplay the discs inserted.
Allanj Jones is offline   Reply With Quote
Old September 7th, 2010, 05:04 AM   #2
did you set Data DVD burn type to UDF 2.5? It won't work when making a regular ISO DATA DVD
and make sure your stream is no more than 15mbps or playback will stutter
Anton Strauss
www.videoproductions.com.au
Anton Strauss is offline   Reply With Quote
Old September 7th, 2010, 06:33 AM   #3
UDF setting
Yes Anton, I did the setting UDF 2.5 type. Just to be clear, I have all the settings correct. I have been trying to crack this now for about 12 months ( ever since I got a HD camcorder and a PS3 ) but no success. The file , when I navigate to it plays flawlessly and the picture is stunningg, but when just inserting the disc into the PS3 it will not play, it just appears as a Data disc and as I said, I then have to navigate on screen using the remote to the folder where the file is and then it plays.
Old September 7th, 2010, 06:53 AM   #4
have you tested it on a standalone Blu-ray player?
which burning software did you use?
did you use DVD-R disks (recommended)
Anton Strauss
Old September 7th, 2010, 08:02 AM   #5
Blu ray
I have burnt with Nero and also with img burn. I only have a PS3 but I have read that others do this same method on a pS3. I did one time a few months ago have access to a stand alone blu player but it did not recognize the disc!
Old September 7th, 2010, 09:56 AM   #6
Try multiAVCHD + ImgBurn. It works great for me.
Chris Davis is offline   Reply With Quote
Old September 7th, 2010, 07:51 PM   #7
it works fine here using nero 10 burning Rom
I select DVD UDF and then set type to 2.5
also, you need to make sure the folder structure is correct
the Certificate folder must be empty and contain and empty BACKUP folder
the BDMV folder must have copies of important files in BACKUP folder
BACKUP
index.bdmv
MovieObject.bdmv
PLAYLIST
00000.mpls
CLIPINF
00000.clpi
Anton Strauss
Old September 8th, 2010, 06:25 AM   #8
Failed again
Yes Anton... already doing this...disc appears on screen as Data disc !! HEEEEEEEEEEELP
Old September 8th, 2010, 07:27 AM   #9
what authoring software do you use? is the first play correctly set?
I use DVDit Pro HD 6.4 and the result works fine, however I don't do it because Blu-ray disks are now cheap enough and the quality is soo much better with the higher bitrate, and they last longer
Anton Strauss
Old September 8th, 2010, 12:50 PM   #10
Blu ray problem
Anton
Thanks for all this help unfortunately the problem continues so the answer is probably to get a blue ray burner. My PC chipset is Nvidia and I have heard some internal burners have probs with this chipset so I thought maybe an extrenal Blu ray USB Writer. Any thoughts on this? Makes? Discs?
Old September 9th, 2010, 12:55 AM   #11
replace the internal burner with a Sata Pioneer 205 (under $200)
external USB burners may cause you headaches
Anton Strauss
Old September 9th, 2010, 01:32 AM   #12
Internal Drive
Hi Anton,
Will my PC be up to the task of a internal... ITs windows XP core2 quad 6600 2.4Ghz. I currently have 2 dvd drives they are TSST corp CD/DVD SH-S1831 and the reason I ask is because these drives are supposed to burn to the 8.5 gb dvds but have never been able to..the burning always fails and I have tried numerous makes of blank discs..they burn fine to standard 4.7 gig discs.. Some time ago I looked into this and was told it was a SATA issue not the drives fault.
Old September 9th, 2010, 02:21 AM   #13
ahahhhhhhhhhhhhhhhh
Win XP can't do UDF 2.5 unless a Toshiba hack is installed
maybe this has been your problem all along
I recommend updating to Win7/64 Ultimate
Anton Strauss
Old September 9th, 2010, 02:56 AM   #14
toshiba drivers
Anton,
I thought that Installing those drivers just allows BD file structure to be recognized in Explorer and allows Blu ray play back in XP. In my case , Nero and IMGburn both have the udf 2.5 option when creating the disc. My problem is not the pc reading/playing the disc its the Play station 3 not auto playing the disc
Old September 9th, 2010, 03:49 AM   #15
I have not tried what you do with XP
I have done it with Win7 and Nero10 burning Rom and the resulting Taiyo Yuden DVD-R plays in all BD related players that support burn media
there are a only few models that don't support burn media on the market
Anton Strauss
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Distribution Center > Blu-Ray Authoring
