#31 |
Re: Encore CS5 Blu-ray
One other thought. Is there a Buffer in Blu-ray players? My disk played just fine the first 2 times I played it. Then on the 3rd time I got glitches all over the place where the audio would cut cut every couple of seconds and the the video would pause also for a second and then start up again. I could see my external SONY speaker trying to switch back and forth between modes trying to play the audio. As I said above the audio and video played great the first two times I played the BR-R disk. This disk has the Canon 60d footage on it. The other disk I created BR-RE had footage from another digital camera and I don't know if the footage is HD or SD if that would make a difference. I edited all footage in the same timeline in PP.
Thanks, John Gerard |
#32 |
I've tried every setting in Compressor without success, and AME can't use AVIs made by FCP. It's confusing because it used to work.
Without a second computer it seems the only reproducible way to burn a Blu-Ray (without Encore re-transcoding it) is to skip Compressor/AME and have Encore transcode it. Either way, Encore will transcode it without giving the user the option to not transcode it. I think it's safe to assume that Adobe will not fix this KNOWN ISSUE since many years have gone by. Since Encore is still the only motion menu (though still unstable in CS5) BR authoring software, we're stuck with the poor quality and long durations of Encore transcodes. |
#33 | ||
#34 |
Thanks Randall. I think I've tried it, but I will see if I can make it work with those settings.
