Which one is better at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Distribution Center > Blu-Ray Authoring
Old June 8th, 2010, 07:58 AM   #1
Which one is better
When output for HD, which encoder is better? MainConcept Mpeg2 .m2ts or Sony AVC? I am using Vegas Pro 9.
Render to MainConcept Mpeg2 .m2t 1440x1080 60i one minute clip results 217mb file size 25,000,000 bit rate.
Render to Sony AVC 1440x1080i @15,000,000 one minute clip results 131mb file size.
View on 1920x1080 monitor I can not tell the different, both are very good. The different I see is the file size. Can you guys/girls give your experience. Thanks you
Bruce
Bruce Phung is offline   Reply With Quote
Old June 8th, 2010, 09:17 PM   #2
If you are satisfied with the end result (which is your main monitor), then obviously go for the smaller file size.
Sareesh Sudhakaran is offline   Reply
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Distribution Center > Blu-Ray Authoring
