My first H.264 encode. What a PIG!!!!
Well, the time has come, and my costumers are asking for Bluray. I've since bought the CS4 suite for such an occasion. I also thought i'd be smart, and archive last week's wedding to BluRay..
I simply opened up Encore, imported the 6 hour long sequence. Set an H.264 8.5vbr Kbps encode for a 1440x1080P 30 fps source (HDV). It was a total of 6 hours of footage... Holy CRAP!!! Over 24 hours later, with my HP workstation crunching with fans running at full blast!!!! Never again! I haven't even tested out a burn to see if it's within BluRay specs... But nonetheless, there's two things i've walked away for the better.. A) I am very impressed with the quality of encode at 8.5Kbps of H.264. It is very sufficient for my needs. Anything more than that, is a waste of bitrate. (I'll cross my fingers for a good burn next). B) I definitely need to step up and get a hardware solution for my encodes. Perhaps even buying another PC, as mine is getting older..It's an HPwx9300 with two DualCore AMD opterons... Is there any suggestions for speedier encodes? I don't mind investing in another computer, but i truly believe that software is not the answer... |
I just bought one of these since I burn to BluRay regularly:
http://www.videoguys.com/Item/Matrox...423F485D4.aspx Can't comment on how well it works yet.
DVX100, PMW-EX1, Canon 550D, FigRig, Dell Octocore, Avid MC4/5, MB Looks, RedCineX, Matrox MX02 mini, GTech RAID, Edirol R-4, Senn. G2 Evo, Countryman, Moles and Lowels. |
Thanks Perrone....
I've already got a Matrox RT.X2 Le card. Unfortunately, i've got no more PCIe slots left. Only PCI-X slots.. Nevertheless, i've seen this hardware before, but never looked deeper into it. There's also the CompressHD cards, but like i said, i'm out of PCIe slots.. Perhaps a render computer, and hardware encoder are in order..... |
