encore menu problem at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Distribution Center > Blu-Ray Authoring
Old November 23rd, 2009, 10:59 PM   #1
encore menu problem
so i'm trying to make a fairly simple menu in encore. 2 buttons with video playing in background and audio, 45 seconds long.
i've got everything built, no errors when i test the build. however, when previewing the disc when i toggle between the two buttons the video and audio will start over. i've tried two methods for the video. just pickwhipping to it and then creating an after effects menu. but both times i get the same problem.
i'm coming from a dvd studio pro world. using macbook pro and encore cs4. thanks for your help!
Michael McQueen is offline   Reply With Quote
Old November 24th, 2009, 12:09 AM   #2
$20 if you help me fix this!
Old December 1st, 2009, 04:13 AM   #3
Have you created an BR image then played it back using Virtual Clone drive. I find when I preview, even after rendering the menus within Encore, I get the same results as you, but the created image and subsequent burned discs play back just fine.
www.griffinvideoproductions.com.au | Sony Z1 and FX1 | Windows 7 x64 | i7-920 OC 3.6GHZ | 12gb DDR3 | CS5.5 Master Collection
Brett Griffin is offline   Reply With Quote
Old December 5th, 2009, 09:46 AM   #4
Brett is correct. This is a Preview issue only. This will not happen on the burned disc.
Jon Geddes is offline   Reply
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Distribution Center > Blu-Ray Authoring
