Current Blu Ray workflow at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Distribution Center > Blu-Ray Authoring
Old January 25th, 2009, 12:48 PM   #1
We are in the middle of switching from Sony Vegas to FCP. Our weddings that are edited in Vegas are simply exported to DVD Architect and burned to Blu Ray discs. Weddings that are edited in FC are a little different. I have been exporting them from FC as reference movies into Compressor. I use the Quicktime H.264 template and turn Quality up to "Best" and leave it as "multi-pass". I then turn on Frame Controls and turn everything to "Better". This leaves me with an 80 GB file. I then move the file over to my PC, pull it into Vegas and have it converted to Blu Ray. I know that I am losing a little bit of quality with the 2nd render in Vegas, but since I turned everything up a bit in Compressor, it usually looks really good.
I was thinking about another option for the Mac. Export the video the same way as I am currently doing, but them pull it into Roxio Toast 10 and have it burn it for me. I'm not sure if Toast will need to recompress it or how well it will recompress.
I don't feel like buying Adobe Encore at this point, but possibly in the future. How does my current workflow sound? Any suggestions/tips?
Chad Dyle is offline   Reply With Quote
Old January 26th, 2009, 03:58 PM   #2
I really would not compress a video to h264, unless it is the final step in the process. It's better to only compress the video once.
I make Blu-Rays (burned onto a DVD though) by exporting Quicktime (not quicktime conversion) of my HDV Final Cut Project as "Pro Res" -and then burning in Toast, which compresses it for me. I don't compress it myself just because it sounds like a hassle to get toast to accept it.
Aric Mannion is offline   Reply With Quote
Old January 26th, 2009, 08:54 PM   #3
So you are saying that Toast will read a Quicktime reference file?
Old January 27th, 2009, 10:14 AM   #4
I assume it can take "reference files" from FCP. It's pointless in my case because I am exporting HDV as Pro res so the "reference file" would have no render files/capture scratch to reference, and would create a large file anyway, so I just use "self contained".
I have read that the menus don't work at all, and Toast will re-encode your video no matter what you give it, but I am only researching "blu-rays" on DVDs, maybe it would work properly on a Blu-Ray disk?
I also read the menus don't work at all.
Old January 27th, 2009, 10:35 AM   #5
I also read that the menus don't work at all.
Old January 29th, 2009, 10:37 AM   #6
-My reply is repetitive because I kept getting errors trying to edit my text.
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Distribution Center > Blu-Ray Authoring
