How do I render for Blu-Ray Disc? at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Distribution Center > Blu-Ray Authoring
Old August 2nd, 2008, 11:03 AM   #1
I need a simple workflow for rendering to Blu-Ray Disc.
I have Vegas 8.0
DVD Architect 5
I tried using the Blu-Ray Mpeg2 template. but i only end up with audio.
Please help!
Thank you!
Darin Holiday is offline   Reply With Quote
Old August 2nd, 2008, 01:32 PM   #2
Make sure if you are doing a MPEG2 render you choose Mainconcept MPEG-2 as the save as type , and also make sure you choose Bluray 1440x1080 in the template box...I should render a file that DVDA5 will see and burn to a Bluray disc, using this template will also keep DVDA5 from rerendering the footage as well.....
David Wayne Groves is offline   Reply With Quote
Old August 2nd, 2008, 06:03 PM   #3
What do you render your HDV footage in Vegas 8 before you import it to DVD Architect 5 ?
They say you can set your menu in DVDA5 and burn A DVD and Blu-ray disc from the same set up, So I am assuming all your renderd footage from Vegas8 is MPEG2(m2t files) right ??????
Michael Ojjeh is offline   Reply With Quote
Old August 2nd, 2008, 06:50 PM   #4
You can also render sony avc blu ray, it will include audio, or mpeg 2 blu ray, render video separate, name video, audio the same, dvda will import audio when you import mpeg2, you didn't indicate if you had blu ray burner, player. etc.
Hugh Mobley is offline   Reply With Quote
Old August 3rd, 2008, 07:38 PM   #5
Hugh,
I have been burning Blu-ray disc from the timeline on vegas 8, But I have not burned any on DVDA5 yet,
I am still not clear what is the best way to burn a DVD and Blu-ray disc from the same menu on DVDA5 ? Is renderd MPEG2 files from Vegas 8 is the right way ?
Old August 5th, 2008, 06:24 AM   #6
Which is likely to give the better results, avc or MPEG2?
Alastair Brown is offline   Reply With Quote
Old August 5th, 2008, 06:42 AM   #7
Images: 10
AVC uses higher compression ratios than MPEG2. It also uses more processor power to decode and playback than mpeg2. AVC can give better results than mpeg2 with some caveats, depending on the encoding bitrate used.
Old August 6th, 2008, 07:57 AM   #8
Thanks for all the help guys! Problem solved. That is why I love this board.
Old August 16th, 2008, 10:50 PM   #9
HDV Cinema
The DVDA 5 manual says to use the Templates in Vegas 8. The manual further says AVC can be up to 40Mbps -- which is correct.
But, the V8 Templates have a 15Mbps setting for AVC. (Which is correct for AVCHD but not for BD.) You can alter it, but only up to 20Mbps. HOW do you get 40Mbps? Or, at least 35Mbps?
PS: Likewise, the MPEG-2 Template setting is only 25Mbps, not 40Mbps.
Old October 2nd, 2010, 04:39 PM   #10
Originally Posted by David Wayne Groves View Post
Make sure if you choose Bluray 1440x1080 in the template box..
Isn't 1920 x 1080 the Blu Ray spec? I'm planning on burning the high def video clip on a standard dvd disc, and was told that if the video length is under about 20 minutes, this would work. This SD DVD disc, containing HD footage, would be playable in a BD player.
Norris Combs is offline   Reply
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Distribution Center > Blu-Ray Authoring
