camera mounting for BMD Hyperdeck 2 at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > BlackMagic Design HyperDeck Shuttle
Old July 24th, 2012, 02:09 PM   #1
I am really getting stuck from how to mount my Hyperdeck 2 to my XL H1 and EX1. Is there any customized or universal mounting for this device?
Much appreciated
Kent Nguyen is offline   Reply With Quote
Old July 24th, 2012, 02:52 PM   #2
Re: camera mounting for BMD Hyperdeck 2
Only one I've seen...
http://www.bhphotovideo.com/c/product/824122-REG/Blackmagic_Design_HYPERD_PTMOUNTPL_HyperDeck_Shuttle_Mounting_Plate.html
Mark
Old July 27th, 2012, 02:15 PM   #3
Yeah I know there are plates. What I wonder is how to attach this plate to cameras. There must be the third party to mount them together.
Old September 5th, 2012, 01:03 PM   #4
The Hyperdeck Shuttle mounting plate replaces the existing back plate, which is held on by screws. It takes all of a minute to make the change. After that, need either an articulating arm or or a tripod clamp to mount the Shuttle either to the tripod or to a clamp that attaches to the camera. The Hyperdeck Shuttle is smallish, but it is a bit heavy/ unwieldy to just attach to a camera for run and gun situations. Further, if you decide on an HDMI connection to the camera, HDMI connectors have a tendency to work themselves loose.
Jay Bloomfield is offline   Reply With Quote
Old March 18th, 2013, 08:11 AM   #5
There is another one i know at least. Its by "Geardear.com" a German Manufacturer. Ive made good experiences. Their stuff is really lightweight. Bought the Mattebox and a Lens Support once.
http://geardear.com/Hyper/andere_5751_532.jpg
Matthias Sachal is offline   Reply With Quote
Old March 18th, 2013, 08:28 PM   #6
Don't overlook the simple.
I build most of my own stuff anyway, and with my 'VG20 and or HV30, I actually have a shoulder mount that made. that I have just added a strip of Velcro to and to the back of Shuttle Hyperdeck. Ugly but it actually works quite well. See photo below.
Chris J. Barcellos
Old April 12th, 2013, 07:49 PM   #7
Here's everything you need for how I did it:
BP Battery Adapter Adaptor V-mount Mount Plate fr IDX Sony D-Tap Power DSLR Rig | eBay
Standard Rail Block | | Berkey System
Blackmagic HyperDeck Shuttle SDI Cable BNC F to DIN 1.0/2.3 RG-179 Cable, 6". | eBay
Dennis Hingsberg is offline   Reply With Quote
Old April 30th, 2013, 10:00 AM   #8
I bought the plate for the $100. It has several holes on the bottom that you can use to mount with. I have a DLSR rig from Lanparte that came with a few single rail mount screws, so I screw it on the bottom of the plate, then slide it over one of the rails and tighten it down. That works for rails setups. Without a rails setup, you'd need some sort of bracket with extra threaded slots and like some others said, some sort of arm or something to mount it. As the other poster showed, using it on a shoulder rig could help as well.
As for the HDMI issue, there is a way to solve that for most cameras, get one of those locking mechanisms, where you put a base plate that is L shaped that has a spot you insert an L hdmi connector, then you tighten the bracket down on the connector so it's in tight, then attach the cord to the L connector. Or you can do something similar where you make your own cheap bracket, plug your cable in, and tighten down around the cord so it doesn't come loose.
Solutions for everything and then some.
Kevin Duffey is offline   Reply With Quote
Old May 2nd, 2013, 04:36 AM   #9
Just came across this versatile mount...
Bracket 1: Video Camera Mounting Accessories
Old April 18th, 2014, 06:54 AM   #10
I have made this cradle for my HDW-750P, and it will fit any v-mount battery camera or accessory.
I lined it with some rubber matting I got as packing with a laptop lithium power supply so it is nicely shielded from vibration.
My one regret is that I have to unclip it from the camera to remove the SSD so if I was to make another I would hinge the lid on the other side. In a way it prevents anyone nicking the SSD I suppose.
If anyone has any questions I would be pleased to answer them.
camera mounting for BMD Hyperdeck 2-dscn1156-1-.jpg   camera mounting for BMD Hyperdeck 2-dscn1155-1-.jpg
camera mounting for BMD Hyperdeck 2-dscn1154-1-.jpg   camera mounting for BMD Hyperdeck 2-dscn1153-1-.jpg
Neil Goodwill is offline   Reply With Quote
Old April 18th, 2014, 02:18 PM   #11
That's great, Neil!
There's a machined version of your creation for sale here: Bracket 1 Cradle Mount for Blackmagic HyperDeck Shuttle VISLBMSC
But I still had to tap my own holes in it to get it to fit the Zacuto Zwiss plate. So irritating how the have all those holes, yet none of them seem to fit anything.
Finn Yarbrough is offline   Reply
  You are here: DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > BlackMagic Design HyperDeck Shuttle
