Wide Angle Pancake Lens for Pocket Cinema Camera at DVinfo.net
BlackMagic Cinema Camera
Old September 21st, 2015, 03:34 AM   #1
Hey Guys,
I'm wanting to use my Black Magic Pocket on my gimbal so looking for a wide pancake lens and wanted to see what options there was.
I think I'd need something around the 10mm - 12mm range and in the £200 - £350 range. Any ideas?
Matt
Matt Thomas is offline   Reply With Quote
Old September 21st, 2015, 04:19 AM   #2
Re: Wide Angle Pancake Lens for Pocket Cinema Camera
Take a look at Samyang. They have a wonderful 7.5mm f3.5 fisheye that is an amazing wide angle on the BMPCC. They also have a 10mm f2.8 and a 12mm f2.0.
I cannot really recommend the 10mm, but only because it is big and heavy. The 7.5mm is very small, with the 12mm being a tad larger. Optically, they all deliver however.
And don't forget that the BMPCC has a crop factor somewhere close to 3x, so that 7.5mm comes in around 20-21mm equivalent.
John Hedgecoe is offline   Reply With Quote
Old September 21st, 2015, 07:09 AM   #3
It may depend on the payload limit of your gimbal.
Do you want MFT and NOT Fisheye?
Rokinon 10mm f2.8 is not Fisheye but weighs 620 grams at $419. This might be the cheapest wide non fisheye but it may be heavy for some very small payload gimbals
http://www.bhphotovideo.com/c/product/1039937-REG/rokinon_10m_mft_10mm_f_2_8_ed_as.html
Panasonic 7-14mm f4 is also not Fisheye and weighs only 300 grams but costs $898. This would probably be the lightest wide non fisheye.
As mentioned above, don't forget the crop factor. 7mm is going to be much wider than 10mm. 7 is about 20mm full frame and 10 is about 29mm full frame angle of view on BMPCC.
If you have a gimbal that can handle a heavy payload then there's
Tokina 11-16mm f2.8 at $429.
http://www.bhphotovideo.com/c/product/882235-REG/Tokina_atx116prodxc_ii_AT_X_116_PRO_DX_II.html
Requires Speedbooster (Nikon or Canon). Token is 550 grams and SpeedBooster is 160g Nikon or 173g for Canon for a total of 720 grams or 723 grams. This will give you wide at about 18mm full frame.
So widest would be Panasonic 7-14mm at 7 or Tokina at 11mm with SpeedBooster. First expensive, second heavy.
I believe some have used a C lens adaptor with a modified Kowa lens.
I believe it's the Kowa 6mm C mount for $599
http://www.bhphotovideo.com/c/product/1022991-REG/kowa_lm6hc_c_mount_6mm_f_1_8_16_1.html
Weighs only 215 grams so probably still light with C-Mount adaptor and probably equal to about 17mm or so Full frame.
Old September 21st, 2015, 07:30 AM   #4
Just for fun, this is everything B&H has for MFT in the 10mm to 12mm range in price order
http://www.bhphotovideo.com/c/search...64&srtclk=sort
Keep in mind that 10mm is probably about 28mm full frame and 12mm is close to 35mm full frame field of view.
Craig Seeman is offline   Reply
