Austinite
Super 16 sensor with a B4 2/3" To Micro 4/3 Adapter
Is it true that a lens with extender (2X) is required to prevent vignetting on a BMD Studio Camera with a MTF Services MTB4M43: B4 2/3" To Micro 4/3 Adapter? The BMD Studio Camera is a super 16 sensor, just like the BMPCC.
Blackmagic Design Studio Camera HD (Super 16mm Sized Image Sensor) 2.88X crop? 12.48 x 7.02 mm – same as BMPCC (Super 16mm Sized Image Sensor) I think there was vignetting was occurring on the MFT 2.5K camera with the MTB4M43 adapter... Blackmagic Design Cinema Camera (MFT Mount) 2.3X crop? Actual: 16.64 x 14.04 mm Anyone have knowledge of this? |
Austinite
Re: Super 16 sensor with a B4 2/3" To Micro 4/3 Adapter
#::nevermind::
This adapter does require the 2x to be engaged on the lens. To use a lens without the 2x engaged, you will need the B4S16M43 optical adapter which is specifically designed for S16 size sensor cameras. https://www.lensadaptor.com/b4-23-su...ro-four-thirds |
B4 on the BMPCC is really nice, except for the CA (which varies from lens to lens). A proper lens makes it a whole different camera :) I just wish someone had an affordable 1.5x TC for B4 - it would be perfect for S16 size sensors and 2/3" ENG lenses...
I own a BMPCC and picked up a $100 to b4 to mft mount from eBay. My 2/3 eng lens does not have a 2x extender and it vignettes quite a bit. Don't really have anything to add about the BMCC, but just confirming that the heavier cropped bmpcc sensor does suffer from vignetting on a standard 2/3 lens. Having used many 2/3 eng cameras on video shoots in the past with a 2x entender. Even those eng cameras don't look great when you engage the 2x extender. In order to properly outfit the BMPCC and BMCC with a quality lens you need to get an more modern 2/3 HD lens, because they seem to have a better optics in the 2x extender. Unless you find a steal, one of those lenses will set you back $4000+
#5 |
Austinite
Mark - we've been selling a lot of this one:
Fujinon XA20sx8.5BERM-K3 HD Lens w/ 2x Extender Product Highlights: - 8.5-170mm for 2/3" Format - 20x Zoom Ratio and 2x Extender - Fast f/1.8 Max Aperture at 8.5-113mm - Manual Focus and Servo Zoom - Innerfocus and QuickZoom |
#6 |
Austinite
The link above is bad now because it was changed for some reason. This works now:
https://www.lensadaptor.com/b4-23-su...cro-43-adaptor B4 2/3" to Super16 Micro 4/3 Adaptor Use B4 2/3" lenses on a Micro Four Thirds mount camera with a Super16 sensor. This means you can use your B4 lenses on the Blackmagic Pocket Cinema Camera. MTF own stainless steel C mount. We recommend you use HD lenses for the highest quality possible. Provision to accept the MTF M/43 & E Mount Support & DTap to 12Pin Hirose Cable. Please note: although it has a Micro Four Thirds mount, this adaptor will not cover anything larger than a Super16 size sensor. There will be approximately 0.8 stop of light loss when using this adaptor. Other Camera Fits: Blackmagic Pocket Cinema Camera, Blackmagic Production Camera 4K, Blackmagic Studio 4K, Blackmagic Studio Camera HD, Micro Four Thirds Other Lens Fits: B4 2/3" |
