BMPCC- A few questions on dropped frames, record times and Codecs at DVinfo.net
BlackMagic Cinema Camera
Old November 3rd, 2014, 10:11 AM   #1
Hi DvInfo users,
I recently bought the BMPCC, and have been enjoying it.
A few questions I havn't been able to find answers to:
-Is there a to check to see if a file has dropped frames after the fact? (Apart from just watching it?)
-Does anyone have experience recording for long periods of time at Prores Lt or Proxy?
-Does anyone who how Prores Proxy would compare to the H264 Codec from the older Canon DLSRs (Like the t3i)?
-Stephen
Stephen Henderson is offline   Reply With Quote
Old March 15th, 2015, 06:39 AM   #2
Re: BMPCC- A few questions on dropped frames, record times and Codecs
According to the ProRes whitepaper, Proxy would have a bitrate of 36 Mbps for 1080p at 24 fps. If I did the math correctly, that would be about a 3.4:1 compression ratio. Assuming the T3i uses a bitrate of 24 Mbps for the same footage, that would be about a 3:1 compression ratio. So compression fairly close.
But the Proxy footage would be 10-bit 4:2:2 (vs the 8-bit 4:2:0 from the T3i). So while it could have more compression artifacts, the color would be much better.
Disclaimer: I don't own either camera; this is just some rough calculations on paper.
Ricky Sharp is offline   Reply With Quote
Old March 23rd, 2015, 10:57 AM   #3
I think it might be a mistake to directly compare the two codecs like that.
You generally need at least 2x the data rate with I-frame codecs like ProRes (all flavours) to equal long-gop type compression that I think AVCHD uses.
Stephen de Vere is offline   Reply
