#16 |
Re: Pocket camera first day, first impressions...
Frame rate is very much over to you and your preference. There is no right or wrong. I shoot at 30 fps and if 60 was available that would be my preference.
I set zebras at 100% and then reduce the aperture one stop below. Film setting as the video setting seems to produce footage that is very contrasty. ISO, I have 400 selected and then outdoor on a sunny day I need ND8 to get the aperture down to about f8 to f 11, the sharp point of my lens. If you want shallow DoF as I believe Jeff wants then you will need a lot of ND's for outdoor shooting, I'm guessing. But as you say this does depend on the conditions and the intensity of the light in your neighborhood. It's not too complicated really. My biggest problem is seeing and reading the screen, but then that's age related to some degree. A bolt-on EVF is on my wish list. |
#17 | |
Cinematographer
I'm not sure why this is the case, but its something to do with the way the protocol is enabled. I'm hoping they will fix this in the future....it's on a growing to do list. Are you shooting RAW or ProRes ? I have some exposure suggestions but it depends how you shoot. EDIT---woops. You won't have RAW yet ;-) I find with ProRes you don't tend to want to ETTR as much as you do with RAW. Mainly because there is less bit depth so it's generally better to have a little more headroom at the top end. When you change the ISO in ProRes, you're also shedding some DR. Even though you're dropping the ISO, all it's doing is mapping the same exposure and applying a more bent curve at the expense of top end. Some users say they prefer the noise profile from this, but it's worth noting that to get the most DR, you should generally shoot at 800 and use ND's. jb |
#18 |
Thanks John, that tip about ISO 800 vs 400 is most helpful. I have now switched to 800 as you suggest so we will see how we go with that.
Im getting there, it is a fun little camera, thats for sure, and I do like the look. |
#19 |
Hey John, any chance this slip means you are currently testing raw?
You motorboating SOB! |
#20 | |
Cinematographer
Also, if you end us using Resolve, there's a great LUT that's been created by a fellow Kiwi there, Captain Hook. It's a great way to shoot FILM and get to a pretty nice result without trying too hard. CaptainHook | Blackmagic Cinema Camera LUT jb |
#21 |
Oh well, then it must be perfect:-)
Thanks, I have downloaded and installed his LUT and tonight I shall give it a whirl. Right now the sun is a-shining, a couple of clouds in the sky just to make it interesting, spring is here, the new lens arrived just 5 minutes ago; I'm off...see ya later! |
#22 |
Try to create some moire (I assume that's what it is)
On a Canon APS-C I find it mild enough to miss when just fooling around, even though it crops up a lot. On some early BMPCs footage you don't see that sort of thing most of the time, but when you do -Pow-, there it is. |
#24 |
Yeah. Thinking I could probably use some examples in case any one asked I tried to find some in the recent footage going around. Haven't been able to yet. Not sure what I saw previously. It's quite possible it was actually on a different camera altogether.
#25 | |
Alex |
