Most Haunted at DVinfo.net
Go Back   DV Info Net > And Now, For Something Completely Different... > Awake In The Dark
Awake In The Dark
What you're watching these days on the Big Screen and the Small Screen.
Old May 19th, 2006, 07:51 PM   #1
Most Haunted
does anyone watch most haunted?
and what do they film th night scene with, i know it's a small consumer camera i think.
Wish I had something witty to say
Tim Goldman is offline   Reply With Quote
Old May 20th, 2006, 02:35 AM   #2
I can't say I watch it, or that I know what cameras they use, but I know they do fake a lot of shots. Things like green and additional noise in post to make a sequence look like it was shot with night vision equipment.
They don't have many scruples.
Marvin Emms is offline   Reply With Quote
Old May 20th, 2006, 03:34 AM   #3
Capt. Quirk
Most paranormal investigators seem to favor the Hi 8 cameras. I'll assume that Most Haunted does too.
www.SmokeWagonLeather.us
K. Forman is offline   Reply With Quote
Old May 20th, 2006, 06:44 AM   #4
Outer Circle
Storm chasers seem to favour the Hi-8 as well, from what I've read. Must be good in lower light and with decent 400 line playback. I assume some models are favoured more, the ones with a bigger CCD. :-)
Old May 20th, 2006, 06:49 AM   #5
Most Haunted use little Sony palmcorders (not sure which model), but they're the upright type, with some sort of built-in light source. It tends to give a hot spot in the centre of the frame if people (never ghosts) get too close.
Apart from that, they use shoulder cams - either Digibeta or 570's with PAG lights as well as a few other lamps on stands around the locations.
As Martin said, they do indeed take liberties with faking "night vision" on cameras which certainly don't have it ;-)
Robin
Old May 20th, 2006, 08:11 AM   #6
Well, the show is entertainment after all.
but how can you tell the night shots from the faked shot, is it that the spot light effect isn't in the shot?
I memeber mtv had that "Scary" show where people ran through haunted places with the camera infreont of them. Wonder what they used
I looked in to a star scope for a dv camera, sheesh lots of $$$
  You are here: DV Info Net > And Now, For Something Completely Different... > Awake In The Dark
