Multi-core hyperthreading with Avid Liquid 7.2? at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Avid Editing Family
Avid Editing Family
All flavors of Media Composer, Symphony and more.
Old May 15th, 2007, 07:18 AM   #1
Does anyone know if Avid Liquid 7.2 is able to take advantage of more than two processor cores? How hyperthreaded is it?
Stephen Knapp is offline   Reply With Quote
Old May 15th, 2007, 12:17 PM   #2
Yes. It really takes advantage of 2nd core by allowing background rendering of effects. Most effects I can still play/edit while effects are rendering. Very robust form the hyperthreading standpoint.
David Parks: DP/Editor: Jacobs Aerospace at NASA Johnson Space Center
https://www.youtube.com/user/JacobsESCG
David Parks is offline   Reply With Quote
Old May 15th, 2007, 05:25 PM   #3
It will not multi-core everything, but as David said. Example, it may only render a single time-warp at a time. It will multi-render 2D CPU effects (A resized of stills that you drop on each). And GPU... single threaded as you probably only have one core ;)
George Ellis is offline   Reply With Quote
Old May 15th, 2007, 09:22 PM   #4
What portion of 8 cores would it be likely to use? Does it perhaps max out at four?
Stephen
Old May 16th, 2007, 03:39 AM   #5
I have run 4 cores at 100% (Ken Burns'ing stills into a 720p movie.) I suspect it can use 8 doing that. I also use Tsunami for encoding and it will use everything it can find (but throttles better). I am now on a dual core system. While faster, sometimes I misses the depth of my dual Xeon (major mobo IDE chipset problem retired it).
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Avid Editing Family
