Can 2-3 pulldown be removed from DNxHD-TR clip? at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Avid Editing Family
Avid Editing Family
All flavors of Media Composer, Symphony and more.
Old May 1st, 2007, 04:30 PM   #1
HDV Cinema
How can 2-3 pulldown be removed from an HD 29.97 DNxHD TR-145 clip?
The clip has 23.98 HD video with the first frame always an A frame.
Old May 2nd, 2007, 01:13 PM   #2
Steve, Just a hunch.
You might try using MPEGstreamclip in reverse. Export 145TR stream out of Avid as HDV, at best quality, import into MPEGstreamclip, convert to QT with 23.98 frame rate setting and pick your best codec dependent on where you're going.
Sorry, that's the best route I could think of.
David Parks: DP/Editor: Jacobs Aerospace at NASA Johnson Space Center
https://www.youtube.com/user/JacobsESCG
David Parks is offline   Reply With Quote
Old May 5th, 2007, 01:39 PM   #3
The new Procoder 3 has a new feature, Inverse Telecine:
http://www.canopus.com/products/ProCoderSW/index.php
This may do it. A call to them would probably clear up any questions about it.
There's a free trial download, so you should be able to try it.
Jack Walker is offline   Reply
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Avid Editing Family
