#16 | |
As far as I can tell from my own experience, Avid's problem with HDV1 is machine control, export settings and mainly ingest. JVC and Avid don't play nicely together, which makes it a real pain to deal with the format. If, however, you manage to capture the footage (and yes, I am only talking about 720p30 here) then editing natively is no problem at all. In fact, there is virtually no difference between HDV1 and DV. All effects that are RT in DV are also RT in HDV1.
www.ascentfilms.com |
#17 | |
What's your workflow in Avid for HDV? Do you just stay HDV all the way or do you use DNxHD at some point? |
#18 | |
HDV Cinema
I too have avoided Avid -- except for Liquid which is a great native HDV editor -- especially on a MBP 2. Avid is so far behind I wonder if they'll ever get caught-up. Like still no dual core support! No ATI support.
Switcher's Quick Guide to the Avid Media Composer >>> http://home.mindspring.com/~d-v-c |
#19 | |
Yes, of course you can transcode native HDV1 to DNx after ingest but ONLY at 720p.30. My point was purely that there is no native support for HDV1 at 24, 25, 50 or 60 fps in Avid's traditional products. If you can't get into Avid, you can't transcode it in Avid! |
#20 | |
The second biggest frustration is that Avid have now inherited the Fast interface, otherwise known as Liquid. I had high hopes for this software back in the day and now I'm extremely upset that it's been taken over by the Avid team. A bit of non-FCP competition at the middle level would have been great. Maybe Canopus/GVG can force their way in there... |
#21 | |
Also, the myth about HDV editing being a problem is also simply that. HDV editing, especially at 720P, is very close to DV. If you are running any G5 or better, or similar on the PC side, you should be editing almost like DV. The only time it gets annoying on my Powerbook G4 are when effects are applied. |
#22 |
720p and Avid
I work with HDV1 (Prohd) and Avid since a year now. I capture and export to tape fine, with no major problems. Real time is even better than in DV.
Lately with the 5.6.1, 5.6.3 updates and QT 7, I have realized that the program became very buggy. I have problems to export m2t, with many error messages, buffer problems, sound problems, corrupted media, etc, almost with every project. A week ago I wanted to import a 34min. m2t, that was exported originally by my avid with lots of trouble, but it stopped at 24min. every time I tried. Has been impossible to import it since then. I re-captured it, as I had it printed to tape, in a new 720p proj., re-exported it again as m2t and it has been impossible ever after to re-import it in the project. Stops at 24min. exactly same frame. I re-captured, re-edited, re-exported, same problem again and again. The reason I wanted to change the spelling of a title. This is a new thing and I wonder if someone can give me some advise for it. The Avid forum ignored my question... With the 5.2.1 - 5.2.2 version I could re-import longer m2ts with no problem. Is this some kind of quota or just a new bug? Bugs... with Avid...? Thanks Panos |
#23 | |
#24 |
That's for sure. The other problem is that many people on the Xpress Pro forum really aren't that experienced with Avid and the MC and Symph guys who are much more likely to be seasoned professionals just steer clear. If you have a problem with a feature that is common to MC (most are) I think it's best to post on the MC board.
Also, the Avid boards suffer from the usual Avid snobbery. A lot of these guys work in facilities or environments where non-linear editing is quite simply synonymous with Avid, so they have no experience with other systems or anything to compare Avid with. The exception is some of the Americans, who might have come into contact with FCP in a professional context. I would also add that - while Avid can work with native HDV on faster machines quite well - the experience is so much more slick on Liquid or Edius. Also, the entire Avid code base and system architecture is a legacy that does not lend itself at all well to the rapidly expanding range of HD formats. Personally, I find the whole 'Open Timeline' thing a bit of a joke because in many ways it's just Avid's way of masking the deficiencies inherent to the product. But that's not to say that the grass is always greener. In general, given an open choice, I'd take Avid over FCP any day. |
#25 |
#26 |
Re import m2t
But why cannot import an m2t dur. 34 min in my avid project? And what is this stoping always at 24min even if it is originated from a different export... So no possibility of the same corrupted frame. Happens on the 5.6.1 5.6.3 with QT 7.1.
Before with the 5.51, 5.52 there was no problem. Does someone have any idea? Is it a new quota... Merry Christmas anyway to all of you and happy-lucky and with 25p support from Avid 2007. Panos |
