Slowmo in Avid Liquid 7-Help! at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Avid Editing Family
Avid Editing Family
All flavors of Media Composer, Symphony and more.
Old August 13th, 2006, 05:44 PM   #1
Hi guys,
I'm having hard time with slowmo in Avid ...Timewarp editor :what are the proper settings for having a smooth slowmo effect ..it's like I'm having the strobo effect instead ...Please need you help!
Todd Evans is offline   Reply With Quote
Old August 14th, 2006, 11:20 AM   #2
Are you setting it for frames and progressive? If I get a chance, I will try to find one of the online tutorials later (no links at this computer)
George Ellis is offline   Reply With Quote
Old August 14th, 2006, 07:04 PM   #3
Thank you George.
I set it to frames but nothing ...it is a little bit better with progressive but still not good..
Old August 14th, 2006, 08:32 PM   #4
If you used Cut Fields, did you check Motion Detection? Also, time-warp needs to full render to playback smoothly. You right click on the bar above the clip (with the sequence number in it) and Force Rendering on that clip (assuming you have Yellow Slices off or rendering off).
Old August 31st, 2006, 03:03 AM   #5
Example footage
Todd, I'm a bit late into this thread.
My edit suite is Avid Liquid 7.1, and attached is an example of a flying stork, reduced to one quarter of its original speed. The settings in Liquid was Cut fields, Motion detection choosed.
The footage is compressed in Sorensen Squeeze Suite 4.2, to a file size of just 812 KB!
Original footage by Brendan Marnell, Irland.
- Per Johan
Old September 1st, 2006, 12:38 PM   #6
What is the source material? DV? Progressive? It makes a big difference as to what settings you'll use.
Stephen L. Noe is offline   Reply
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Avid Editing Family
