SDI Output-Input Into Avid Xpress Pro 5.5 at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Avid Editing Family
Avid Editing Family
All flavors of Media Composer, Symphony and more.
Old July 2nd, 2006, 01:17 PM   #1
Okay, as you're all aware I have several reels of Canon XLH1 24 Frame footage, and I cannot input it via Firewire without it playing erroneously (it looks sped up). So, can I input via an SDI Mojo using Serial Digital Output? What are your thoughts?
Brad Schreiber is offline   Reply With Quote
Old July 2nd, 2006, 01:29 PM   #2
Brad, are you on a Mac or PC?
Best,
Christopher
Christopher Glaeser is offline   Reply With Quote
Old July 2nd, 2006, 01:37 PM   #3
Mac or PC
I have access to both, but my main work is done on PC. I have an older Mac, a Dual 1Ghz G4 with 1 GB of RAM that runs AXP tolerably well, at least enough for a dig station.
Old July 2nd, 2006, 01:55 PM   #4
You should be able to if the Mojo/Avid accepts an HD-SDI 1080i spec signal.
Barlow Elton is offline   Reply With Quote
Old July 2nd, 2006, 04:03 PM   #5
Have you tried to capture the m2t files using firewire and Cineform HDLink?
Best,
Christopher
Old July 2nd, 2006, 04:25 PM   #6
Cineform HDLink?
I have never heard of this. Will investigate...
have you used this, does it work well?
Old July 2nd, 2006, 04:40 PM   #7
I use HDLink to capture all my XL H1 footage. There is a free trial on the Cineform website. I don't use Avid and I don't know if there are better options for you to capture, but I think Aspect HD (which includes HDLink) is the best option for Premiere users.
At minimum, you will at least determine if you can capture m2t files.
Best,
Christopher
Old July 2nd, 2006, 05:42 PM   #8
HDLink
Do you capture via firewire or SDI?
Old July 2nd, 2006, 05:51 PM   #9
HD for Indies
Mojo SDI is SD ONLY
Yep. So that won't work.
Mike Curtis
HD For Indies - Hi Def Filmmaking & Post for
Independent Filmmakers
http://www.hdforindies.com
mike@hdforindies.com
Mike Curtis is offline   Reply With Quote
Old July 2nd, 2006, 06:26 PM   #10
Avid adrenaline can capture HD over HD-SDI and convert to DNxHD over firewire. Mojo is SDI only so far as Mike said. Though It might be cheaper to get a HD-SDI card to capture with than getting an avid adrenaline.
I would suggest having someone ingest the footage for you over HD-SDI if you don't have the facilities for it and don't plan on upgrading.
Keith Wakeham is offline   Reply With Quote
Old July 2nd, 2006, 07:24 PM   #11
Cineform AVI into Avid
Okay, tried Cineform, works like a charm. Excellent referral, thank you so much. the problem is, the AVI will not go into Avid Xpress pro 5.5. Any suggestions on getting it in?
Old July 3rd, 2006, 11:09 AM   #12
Use cineform but in the preferences section select the option that just captures the m2t files and import the m2t's into Avid. Avid will not read CF AVI's.
Old July 4th, 2006, 08:42 AM   #13
Use Hdv-split
I use "HDV split 0.75" its FREEWARE and captures perfectly .m2t files from my XLH1 and has scene detection!!!
Michael Karrer is offline   Reply
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Avid Editing Family
