Editing the waves at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Avid Editing Family
Avid Editing Family
All flavors of Media Composer, Symphony and more.
Old March 2nd, 2010, 12:06 PM   #1
Editing the waves
I'm using the trial version of MC and I really like it. But I've run across an odd audio problem.
I can't get the audio waves to show on the timeline, even with "sample plot" clicked in audio data. The waves only show when I set an In and Out.
Then, when I put down keyframes to manually adjust the waves, I'm not able to do anything other than move the whole level bar and keyframes up and down; the keyframes don't work independantly.
However, if I switch off the waves - by eliminating an in and out - I can set keyframes and adjust the audio.
Nathan Swinn is offline   Reply With Quote
Old March 3rd, 2010, 06:43 AM   #2
I solved the problem with the help of this vid: No Visible Waveform or Audio Level Plot - Avid Video Community
Which I found amoungst the over two hundred tutorials posted by drbgaijin on the avid forum (links to over two hundred vids are posted in a thread on this forum; should probably be a sticky).
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Avid Editing Family
