Audio Stutter at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Avid Editing Family
Avid Editing Family
All flavors of Media Composer, Symphony and more.
Old September 18th, 2009, 07:18 PM   #1
Audio Stutter
Just transfered all my files from multiple IDE drives to one sata drive. Everything appears to be working fine EXCEPT for an Audio Stutter on the sequence playback, the source playback is fine.
Any ideas ?
Steve.
Last edited by Steve Elgar; September 18th, 2009 at 09:03 PM. Reason: Hearing aid fell out.
Steve Elgar is offline   Reply With Quote
Old September 19th, 2009, 08:52 PM   #2
Need more info. What codec, resolution and framerate are you editing. Are you sure that your sample rate is correct on your sequence? Like source is 44.1 but your sequence is 48?? It should have warned if this the case though.
Anyway, let us know more what your doing and we'll bird dog it for you.
David Parks: DP/Editor: Jacobs Aerospace at NASA Johnson Space Center
https://www.youtube.com/user/JacobsESCG
David Parks is offline   Reply With Quote
Old September 20th, 2009, 12:10 AM   #3
Hi Dave, that was timely. I just fixed the problem. Not sure exactly what it was but I changed sata connections to another plug on the MoBo and now everything appears to be working fine. I should have tried that days ago, but I hate changing things inside computers.
Steve.
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Avid Editing Family
