AVCHD to DNxHD at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Avid Editing Family
Avid Editing Family
All flavors of Media Composer, Symphony and more.
Old April 25th, 2009, 04:15 AM   #1
AVCHD to DNxHD
Is the conversion of AVCHD to DNxHD possible?
Any information on any type of similar workflow would be very helpful.
Visit my work at www.atheaton.gr
George Pada is offline   Reply With Quote
Old April 28th, 2009, 02:30 PM   #2
re
From Panasonic camcorders you can make easy conversion to DVCPRO HD (it can be native edited in MC).
From other AVCHD you can use other utilities of manufacturers, or other conversion in Vegas or Edius to MXF or DVCPRO HD and so on (better camcorders use DVCPRO HD or MXF, AVCHD is new).
Pavel Sedlak is offline   Reply With Quote
Old July 30th, 2009, 03:49 PM   #3
Problem solved
Thank you for the reply!
Old July 31st, 2009, 03:57 PM   #4
Sorenson Squeeze (which comes w/ Media Composer) and TMPGEnc Xpress 4.0 both do AVCHD to DNxHD conversion.
If you select the proper settings for your Avid project type, the DNxHD QT file will fast import into MC w/o an additional transcode.
Avid Media Composer 3.1.3. Boris Red and Continuum Complete. Vegas 8.0c. TMPGEnc Xpress Pro 4.0
Old August 4th, 2009, 03:38 PM   #5
Peter what version of Sorenson Squeeze are you using for this?
David M. Spell is offline   Reply With Quote
Old August 4th, 2009, 08:30 PM   #6
5.1.0.
Hope that helps.
P.S. Although it looks like the latest version is 5.1.1.16, which I just got a message to download, LOL.
Old August 26th, 2009, 01:11 PM   #7
Hi, I hope you don't mind me asking but how are you getting the avchd files into Squeeze? Are they avchd or avc-intra files? When I try to import Canon HF100 files into Squeeze I get an error message that the file format is not supported!
Gerwyn Bowen is offline   Reply With Quote
Old August 26th, 2009, 10:24 PM   #8
What's the extension of the file?
Old August 28th, 2009, 10:03 AM   #9
The file extension is .MTS and are files from a Canon HF100.
Old August 29th, 2009, 01:34 AM   #10
I have used .mts files with Squeeze, but haven't tried files from the HF100. If there's a way for me to get sample footage, I'd be more than happy to try it out.
Peter Moretti is offline   Reply
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Avid Editing Family
