#16 | |
#17 |
Hi Ola,
O.K. So (until Avid corrects this glitch) what's your workflow now? Do you still use AMA, or are you back to using Clip Browser to convert to mxf? (I'm wondering if I should put off upgrading to 3.5 until this is fixed). Malcolm |
#18 |
Actually, Avid announced yesterday on their forum that they have found the bug and that a fix should not be far away. I´m currently editing a documentary that was ingested months ago and will be doing this for the next couple of months so I´m only using ama to play with for now.
#19 |
Ola:
Did the AMA/audio timeline problem ever get the bug fixed? And another question: have you tried bringing EX video into the AVID at an offline resolution, and then trying to re-digitize at full resolution? If so, what was the workflow, and how did it do? Thanks! |
#20 | |
And no - I have not tried transcoding to an off-line resolution. The EX-format does not do proxies and I cannot see any reason downressing for editing. With todays hard disk prices why would you want to off-line 35 mbit EX-material?! |
#21 |
I have a major client that uses an AVID Unity/Interplay system, and handles almost all HDCam tape source material. I would like to eventually supply them with EX-3 video (either from the SDHC cards, or the Convergent Design Compact Flash cards at 100mbs 4:2:2)
However; their workflow is to import everything into the MC at 15:1, and then do a full rez conform on a Symphony, so they can keep their storage needs manageable. They are a little unsure how to handle the low rez import/conform with a file-based card source, not to mention the archiving issues. Right now, I don't have anything intelligent to suggest to them. They are exploring adding XDCam Pro discs to their system in the near future, so I suppose there is a way to dump the EX-3 files onto the Pro disc and ship that off for starters. |
