Importing pictures into avid express pro look horrible need help!!!!! at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Avid Editing Family
Avid Editing Family
All flavors of Media Composer, Symphony and more.
Old December 29th, 2008, 09:16 PM   #1
I've got a buddy who owns a avid express studio system
he is trying to import some jpeg pics into his timeline. When he imports the pics and puts them on the timeline they look horrible and they look horrible when he outputs to a dvd.
almost blurry looking he says
any tricks or settings he needs to change
any help greatly appreciated!!!!!
Take a kid hunting or fishing and you won't have to hunt for him or her later on in life. The outdoors were created to enjoy not look at through a glass window.
Torrey C. Harris is offline   Reply With Quote
Old December 29th, 2008, 10:18 PM   #2
Try using the Avid Pan & Zoom and load the image via the plugin, works pretty well and you even have some options to select what filter you use when you zoom into the image.
here is a tutorial Using Pan and Zoom with Avid Xpress - Final Cut Studio, Avid, Adobe, and Video Streaming Training
I think the image size limit is 3000x3000
Peter Szilveszter is offline   Reply With Quote
Old December 29th, 2008, 10:36 PM   #3
In Control Panel of Avid, choose imagge import option, check to fix screen.Your jpeg images will fix the size of your timeline
Vinh Nguyen Quang is offline   Reply With Quote
Old December 29th, 2008, 10:46 PM   #4
This still gives you low image quality, the Avid Pan & Zoom is specifically designed for importing still images to maintain the higher resolutions.
Old December 30th, 2008, 08:39 AM   #5
Avid Pan and ZOom is the way to go. IT gives you the option of changing the resolution and also the fields. Make sure when he imports the stills, he is selecting the right formats. It's a very good program, I just did a ten minute video of all pan/scans - looks beautiful.
Richard Alvarez is offline   Reply With Quote
Old December 30th, 2008, 02:31 PM   #6
Photoshop the Jpegs
adjust the pixels to match the project (image/ pixal aspect ratio)
adjust the size to match the project (image/ image size)
save as a tif or pict (file/save as/format)
drop them in a bin
edit them in
aloha
tito
Tito Haggardt is offline   Reply With Quote
Old December 30th, 2008, 05:55 PM   #7
Originally Posted by Tito Haggardt View Post
Photoshop the Jpegs
drop them in a bin
edit them in
aloha
tito
This is ok if you just want a full screen image, but if you want to pan or zoom on the image this gives very poor results. As said earlier use Pan & Zoom for images regardless of aspect or size, nothing else will give as good results within Avid other then using Avid FX.
Old December 31st, 2008, 02:11 PM   #8
thanks Peter
i will give it a go
tito
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Avid Editing Family
