Thread Tools
Search this Thread
How to create SD and HD mixed Project
I have a project that uses both 16mm and HD footage. The 16mm is not necesarily 24 frames anymore since it has been output to SD digibeta, and then to quicktime file, and reimported back into Avid. The problem I am having is that there are format issues, how do I create a project with 2 different kinds of formats? the 16mm footage is about a 1:66 ratio and the HD footage is 16:9.
When i start a new project, they only offer a few options which does not include a mix format project, how can i get SD and HD to work together, and still keep each format's ratio in tact? Thanks, Kevin
Kevin Ta |
Kevin,
What is your final output?? Is it for projection or is it for a monitor/television??? You can mix HD and SD in a timeline, for example 1080i, and switch back and forth with the format tab for preview on how that will work. But, ultimately, you need to know where you are going. Let us know what your final output is going to be and I can guide from there. David
David Parks: DP/Editor: Jacobs Aerospace at NASA Johnson Space Center https://www.youtube.com/user/JacobsESCG |
You just need to make a 1080i project and when you go to capture the Digibeta just hit the format tab to SD and you will have the capture settings of a SD project. Once in the timeline your HD or SD clips will be color coated depending on what format you are in. That means if you are in HD settings all your SD clips are colored. I have yet to actually output a mixed resolution timeline because we always upconvert through a Teranex before we color correct and finish.
