Composer Window in Left Monitor Best? at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Avid Editing Family
Avid Editing Family
All flavors of Media Composer, Symphony and more.
Old September 8th, 2008, 05:39 AM   #1
I just read while searching for answer to a different ? that the Composer Window should be in the left monitor of dual monitor setup. Is this correct?
Third post from top: http://community.avid.com/forums/p/1...355.aspx#96355
I have mine in the right window, but do have infrequent odd behavior, like Help not disappearing properly or clips not playing.
Thanks.
Old September 8th, 2008, 12:26 PM   #2
Peter,
I use composer on the right and bins on the left without any problems. So this is new to me.
I do know that you have to identify which monitor is full screen capable in the Full Screen Playback settings. Are both your monitors set to the same resolution?
David Parks: DP/Editor: Jacobs Aerospace at NASA Johnson Space Center
https://www.youtube.com/user/JacobsESCG
David Parks is offline   Reply With Quote
Old September 8th, 2008, 07:33 PM   #3
I've read that restriction before as well, and don't know if it's an Avid issue, or a video card hardware/driver issue. I know that I've seen other applications that won't play video properly on my right screen.
Do you have your screens set as independent, or as one big screen? You might want to mess with that to see if it makes a difference.
http://www.nosmallroles.com
Vito DeFilippo is offline   Reply With Quote
Old September 10th, 2008, 12:17 PM   #4
Third post from top: Composer window freeze during re-size - Avid Community
Thanks.
That thread is from 2006 and is just that moderator's opinion. You can have your composer window in the right monitor which is what I do, no problems.
j
Jeff Cerar is offline   Reply With Quote
Old September 10th, 2008, 12:54 PM   #5
left or right doesn't mean anything. you have to specify if it is primary or secondary display.
screens can be arranged in every way, so position is not relevant.
Giroud Francois is offline   Reply
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Avid Editing Family
