24 bit sound - Possible?? at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Avid Editing Family
Avid Editing Family
All flavors of Media Composer, Symphony and more.
Old May 20th, 2008, 09:26 AM   #1
Hello,
I have Liquid 7.2 and am trying to import a 24 bit wav sound into Liquid. When I try and do so the program indicates an error because it is an unsupported format. Is this true?
If so, how do I go about converting the 24 bit sound to 16 bit sound which seems to work fine when importing?
Thanks Brian
Brian Jacobsen is offline   Reply With Quote
Old May 20th, 2008, 08:16 PM   #2
Check out Audacity, a freeware wav editor. Perhaps it can do the conversion.
http://audacity.sourceforge.net/
Adobe Audition could do it for sure if you have it.
http://www.nosmallroles.com
Vito DeFilippo is offline   Reply With Quote
Old May 23rd, 2008, 04:49 PM   #3
Hello,
I have Liquid 7.2 and am trying to import a 24 bit wav sound into Liquid. When I try and do so the program indicates an error because it is an unsupported format. Is this true?...
It's true. I just ran a test and the 24 bit 48k file would not import. However, I converted it to 32 bit (floating point) 48k and it worked great.
I use WaveLab. It's works very well with Liquid. I normally export all the audio tracks from Liquid and do my final mix in WaveLab in a multitrack montage.
Instead of going back to 16 bit file...I would recommend rendering it to a 32 bit, 48k.
Jim Boda is offline   Reply
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Avid Editing Family
