applying a 16:9 mask on entire timeline at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Avid Editing Family
Avid Editing Family
All flavors of Media Composer, Symphony and more.
Old August 24th, 2007, 04:04 AM   #1
Hi everybody,
I've got an entire timeline (avid xpress pro) of 4:3 footage which I want to mask to match 16:9. How can I apply the effect to the entire timeline at once? Are there any other settings I should find to do this right (pixel aspect ratio, resolution)?
greetz,
Merlin
Canon XM-2
AVID Xpress Pro 5.7
Merlin Vandenbossche is offline   Reply With Quote
Old August 24th, 2007, 08:52 AM   #2
Merlin,
You can use Film>16:9 Mask. To apply to the entire timeline you Lasso the time line. Place the mouse on the timeline at the front end at the video track. Hold down the mouse button and drag the lasso to the right this should highlight. Or you can shift click.
Don't use 16:9 from reformat. It will squish you footage top and bottom.
Cheers.
David Parks: DP/Editor: Jacobs Aerospace at NASA Johnson Space Center
https://www.youtube.com/user/JacobsESCG
David Parks is offline   Reply With Quote
Old August 24th, 2007, 09:25 AM   #3
I do the same thing but a little different. I create a new video track and apply a submaster effect to the entire track. Then I add the 16:9 mask (or 1.85:1 mask, 1.66:1 mask, Anamorphic mask, whatever you choose) to the submaster. Both ways get you where you want to be put I prefer this method as I think it's a bit quicker, and you're only applying one effect that covers the entire sequence rather than a bunhc of effects.
Then I like to go through the entire timeline and position any clips which may not be framed as I like them. That's my main reason for letterboxing clips even if the output is SD. It's nice to be able to move the clips up or down and fix any bad framing issues that may have been made while shooting.
Matthew Craggs is offline   Reply
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Avid Editing Family
