Sony's AVCHD cams announced
http://www.sony.jp/products/Consumer...DUCTS/HDR-SR1/
AVCHD is H.264 based agreed by Sony and Panasonic. The ones by Sony seems to be only connected via USB. |
I don't understand why they don't use HDV as the recording spec......why introduce a new spec when we're just getting our NLE's to edit HDV!!!!
Soon their will be too many HD variants and incompatibilties across the board- NLE's will need constant updating to keep up with ever changind HD variants......I wish they would have followed DV and used it upscaled instead of the mpeg-2/4 variations......... ...Apple users will have the most problems as PC's account for far many users although Apple users are more prone to try video editing as their machines are touted for such purposes.... ...technology presses on although in too many directions for mass adoption! |
#3 | |
#4 | |
#5 |
I will go to Sony Plaza
like how I did with FX1.
It looks like Sony will have a handson seminar at Sony Plaza in August with UX1. http://www.sony.jp/event/iteseminar/...ux1/index.html |
#6 |
My biggest worry is artifacts.
#7 |
can somebody CONFIRM? no 24p this time???
Just want to know - definitely 60i at this point? Or any "p" as in 720 or... egads... 1080 24p - guess not, eh? Like, they would have touted it bigtime with the official news release...
dang! |
#8 |
Kaku
There is a bit of debate about the actual data rate these recorders are using over here: http://www.dvinfo.net/conf/showthread.php?t=71876 About the meaning of the Japanese text next to VBR in this spec page: http://www.sony.jp/products/Consumer...-SR1/spec.html It seems to be saying that 15mb/s is only the average, not the top bit rate. I am very eager to clarify which it is, because we could virtually order camera after first review, if it is only the average and not the max? If you could come over there and help use that would be good. Thanks Wayne. |
#9 |
From the spec. describes,
High Vision (HD) Quality Approx. 15Mbps@XP mode, Approx. 9Mbps@HQ mode, Approx. 7Mbps@SP mode, and Approx. 5Mbps@LP mode. Standard Quality Approx. 9Mbps@HQ mode, Approx. 6Mbps@SP mode, and Approx. 3Mbps@LP mode. All is Variable bit rate. Doesn't say much about the top rate. And for Mark's questions, it is basically 1080/60i. Also, it has the same memory record function as HC3, 3 seconds of 240field/sec. capturing recorded as 12 seconds of 60field/sec (overcrank). Also, records sound in surround with extra microphone. |
#10 |
Kaku, thanks. Does the wording beside VBR, indicate that 15mb/s is an average figure, or does it just indicate that VRB is averaging?
Look forward to seeing your review ;). |
#11 | |
#12 |
Kaku, thank you very much for this, it is what i expected, does not really indicate that it is an average value.
#13 |
I forgot to ask, any cameras you plan on looking at around the place?
Thanks Wayne. |
#14 |
main specs translation
here is what my translation program spits out:
The main specifications 機 Opportunity Ability 表 Table イメージセンサー Image sensor イメージセンサー Image sensor 1/3型クリアビッドCMOSセンサー 1 / 3 type clear ビッド CMOS sensor 記録画素数 The number of record pixels 静止画時 At the time of a still picture 最大400万画素相当 A maximum of 4 million pixels 総画素数 The total number of pixels 210万画素 2,100,000 pixels 有効画素数 The number of effective pixels 動画時 At the time of an animation 143万画素(16:9時) 108万画素(4:3時) It is 1,080,000 pixels (4:3:00) 1,430,000 pixels (16:9:00). 静止画時 At the time of a still picture 149万画素(16:9時) 199万画素(4:3時) It is 1,990,000 pixels (4:3:00) 1,490,000 pixels (16:9:00). レンズ Lens レンズ Lens カール ツァイス「バリオ・ゾナーT*」レンズ Curl ツァイス "バリオゾナーT*" lens ズーム Zoom 動画時 At the time of an animation 光学10倍 デジタル80倍: 10 times as many optics as this Digital 80 times as many as this : プレシジョンデジタルズーム Precision digital zoom 静止画時 At the time of a still picture 光学10倍 10 times as many optics as this フォーカス Focus 自動/手動(リング・タッチパネル)/リニアマッハAF Automatic / manual operation (ring touch panel) / linear Mach AF F値 F value F1.8~2.9 F1.8~2.9 f(焦点距離) f (focal length) f=5.1~51mm f=5.1~51mm f(35mm換算) f (35mm conversion) 動画時 At the time of an animation f=41.3~485mm(16:9時) 50.5~594mm(4:3時) f= 41.3-485mm (16:9:00) 50.5-594mm (4:3:00) 静止画時 At the time of a still picture f=40.4~404mm(16:9時) 37~370mm(4:3時) f= 40.4-404mm (16:9:00) 37-370mm (4:3:00) フィルター径 The diameter of a filter 30mm オートレンズカバー Auto lens cover ● - テレマクロ Tele broad view ● - ビューファインダー/ View finder/ 液晶モニター Liquid crystal display monitor ビューファインダー View finder 0.27型(16:9)/12.3万ドット 0.27 type (16:9) / 123,000 dot 液晶モニター Liquid crystal display monitor 3.5型(16:9)/21.1万ドット 3.5 type (16:9) / 211,000 dot クリアフォト液晶プラス Clear photograph liquid-crystal plus タッチパネル Touch panel ● - カメラ Camera 最低被写体照度 The minimum photographic subject illumination 11ルクス(ナイトショット撮影時0ルクス) 11 luxs (time of night shot photography 0 lux) 手ブレ補正機能 Blurring compensation function ●(新アクティブイメージエリア方式) - (New active image area system) シャッタースピード Shutter speed 1/4~1/500秒*1 1/4-1/500 second *1 ホワイトバランス White balance 自動/ワンプッシュ/屋外/屋内 Automatic / one push / outdoors / indoor ホワイトバランスシフト White balance shift ●(9段階) - (Nine stages) 明るさ調整 Brightness adjustment ● - AEシフト AE shift ●(9段階) - (Nine stages) 逆光補正(ボタン) Backlight compensation (button) ● - ゼブラパターン Zebra pattern ● - レコーダー/プレーヤー A recorder/player 記録メディア Record media ハードディスク Hard disk 容量/サイズ Capacity/size 30GB /1.8インチ 30GB / 1.8 inches HDD落下保護機能 HDD fall protection function HDDスマートプロテクション HDD smart protection 映像記録 Image record HD画質:MPEG4 AVC/H.264 SD画質:MPEG2 HD Quality-of-image: MPEG4 AVC/H.264 SD quality-of-image:MPEG 2 音声記録 Voice record ドルビーデジタル5.1ch(内蔵マイク) ドルビー digital 5.1ch (built-in microphone) ドルビーデジタル2ch(別売マイク) ドルビー digital 2ch (option microphone) 風音低減 風音 reduction ●(自動) - (automatic) 録音レベル調整 Recording level adjustment ●(2段階) - (Two stages) 動画画質(平均ビットレート/VBR) Animation quality of image (mean bit rate / VBR) ハイビジョン画質 High-definition television quality of image XP:約15Mbps/HQ:約9Mbps/SP:約7Mbps/LP:約5Mbps XP: SP:abbreviation 7Mbps [ about 15 Mbpses/HQ:about 9 Mbpses /, and ]/LP gas:abbreviation 5Mbps スタンダード画質 Standard quality of image HQ:約9Mbps/SP:約6Mbps/LP:約3Mbps HQ: SP:abbreviation 6Mbps [ about 9 Mbpses / ]/LP gas:abbreviation 3Mbps データコード Data code ●(撮影日時、カメラ情報) - (Photography time, camera information) オリジナル編集 Original edit ●(削除) - (Deletion) プレイリスト編集 Play list edit ●(追加、削除、移動) - (An addition, deletion, movement) 静止画 Still picture 静止画サイズ Still picture size 静止画モード時 At the time of the still picture mode 400万画素相当 4:3(2,304×1,728) 4 million pixels 4:3 (2,304x1,728) 300万画素相当 16:9(2,304×1,296) 3 million pixels 16:9 (2,304x1,296) 190万画素相当 4:3(1,600×1,200) 1,900,000 pixels 4:3 (1,600x1,200) 30万画素相当 4:3(640×480) 300,000 pixels 4:3 (640x480) 動画撮影時 At the time of animation photography 230万画素相当 16:9(2,016×1,134) 2,300,000 pixels 16:9 (2,016x1,134) 170万画素相当 4:3(1,512×1,134)*2 1,700,000 pixels 4:3 (1,512x1,134)*2 静止画記録メディア Still picture record media “メモリースティック デュオ”/ "memory stick duet "/ “メモリースティック PRO デュオ”/ハードディスク A "memory stick PRO duet" / hard disk フラッシュ Flash ●(プリフラッシュ調光) - (プリフ rushes tone light) ピクトブリッジ ピクト bridge ● - その他 Others アクセサリーシュー Accessories shoe ●(アクティブインターフェースシュー) - (Active interface shoe) 本体内充電(付属バッテリーの満充電時間) Charge in a main part (満充電 time of an attached battery) ●(約2時間30分) - (About 2 hours and 30 minutes) 仕 仕 様 It needs. 比 Ratio 較 較 表 Table システム System 映像入出力端子 Image input-and-output terminal HDMI端子 HDMI terminal ● - コンポーネント端子 Component terminal 特殊D端子(D3/D1出力対応) Special D terminal (D3 / D1 output correspondence) 映像入出力 Image input and output 特殊コネクター(出力のみ) Special connector (only output) S映像入出力 S image input and output 特殊コネクター(出力のみ)(別売AVケーブル使用) Special connector (only output) (option AV cable use) 音声入出力端子 Voice input-and-output terminal 特殊コネクター(出力のみ)(映像出力端子と兼用) Special connector (only output) (an image output terminal and combination) USB端子*3 USB terminal *3 ●(mini-B/USB2.0 Hi-Speed) - (mini-B/USB2.0 Hi-Speed) REMOTE(リモート)端子 REMOTE (remote) terminal ● - ヘッドホン端子 Headphone terminal ステレオミニジャック Stereo mini jack マイク入力 Microphone input ステレオミニジャック Stereo mini jack 基本バッテリーシステム Basic battery system “インフォリチウム”Mシリーズ対応 "Information lithium" M series correspondence 電源電圧部 Power supply voltage part ACアダプター8.4V/バッテリー7.2V AC adapter 8.4V/battery 7.2V 消費電力 Power consumption (動画撮影時) (at the time of animation photography) ビューファインダー使用時 At the time of view finder use 4.8W 液晶モニター使用時 At the time of liquid crystal display monitor use 4.9W 外形寸法:幅×高さ×奥行*4 Outside Size: Width x height x depth *4 (付属バッテリー装着時) (at the time of attached battery wearing) 78×84×165mm(78×84×165mm) 78x84x165mm (78x84x165mm) 本体質量 The amount of these constitutions 約640g About 640g 撮影時総質量*5 the time of photography -- the total -- mass *5 約720g(NP-FM50〈本体付属品〉使用時) About 720g (at the time of NP-FM50 <main part accessories> use) 約800g(NP-QM71使用時) About 800g (at the time of NP-QM71 use) 約870g(NP-QM90使用時) About 870g (at the time of NP-QM90 use) *1:カラースローシャッターは1/4~1/250、なめらかスロー録画は1/240~1/500 *1: For a color slow shutter, 1 / 4 - 1/250, and smooth slow videotape recording are 1 / 240 - 1/500. *2:スタンダード画質のみ *2: Only standard quality of image *3:WindowsR98以前、Mac OS X 10.1.5以前のOSを搭載したパソコンには対応していません。 *3: Don't correspond to the personal computer which carried OS before Mac OS X 10.1.5 before WindowsR98. 対応OS搭載パソコン以外のUSB端子搭載機器(テレビ、DVDレコーダーなど)での動画、静止画の再生・転送はできません Reproduction and transmission of the animation in USB terminal loading apparatus other than a correspondence OS loading personal computer (television, DVD recorder, etc.) and a still picture cannot be performed. *4:最大突起部を含む *4: The maximum projection part is included. *5:バッテリーを含んだ質量です *5: It is the mass containing the battery. 付属品 Accessories リチャージャブルバッテリーパック(NP-FM50)、ACアダプター 、特殊D端子コンポーネントビデオケーブル、AVケーブル、USBケーブル、CD-ROM(WindowsR用ソフト「Picture Mo tion Browser」) 、ワイヤレスリモコン(RMT-835)、その他 a リチャージャ bull battery pack (NP-FM50) and AC adapter a special D terminal component video cable, AV cable, USB cable, CD-ROM (software for WindowsR "Picture Motion Browser"), and wireless remote control (RMT-835) -- in addition *“メモリースティック デュオ”、“メモリースティック PRO デュオ”は付属していません * The "memory stick duet" and the "memory stick PRO duet" are not attached. 連続撮影時間の目安 (実用充電からさらに1時間充電すると満充電になります) Standard of continuation photography time (it will become 満充電 if it charges from practical use charge for 1 hour) ビューファインダー View finder 使用時 At the time of use リチャージャブル リチャージャブル バッテリーパック Battery pack 連続撮影時間 Continuation photography time 実撮影時間 Real photography time NP-QM91D 約6時間15分 About 6 hours and 15 minutes 約3時間25分 About 3 hours and 25 minutes NP-QM71D 約4時間05分 About 4 hours and 05 minutes 約2時間15分 About 2 hours and 15 minutes NP-FM50(付属品) NP-FM50 (accessories) 約1時間40分 40 minutes per hour [ about ] 約55分 About 55 minutes 液晶モニター Liquid crystal display monitor 使用時 At the time of use リチャージャブル リチャージャブル バッテリーパック Battery pack 連続撮影時間 |
#15 | |
