Example 25i vs 50p - Page 2 at DVinfo.net
AVCHD Format Discussion
Old June 15th, 2011, 07:40 AM   #16
Re: Example 25i vs 50p
The special case of psF indicates a single Frame split into separate fields. You are correct in understanding that a typical recording has two fields separated temporally, in a psF recording a single Frame is split into two fields that can be reconstructed into a single Frame without any temporal separation.
Cheers,
GB
R Geoff Baker is offline   Reply With Quote
Old June 15th, 2011, 09:22 AM   #17
Understood. The interlace stream is acting as a carrier for the source progressive input whether its 30 fps or 24fps ( for NTSC as an example) with just different pulldowns that the NLE will use to reconstruct the source progressive file.
Ron Evans.
Ron Evans is offline   Reply
