Batch transcode many AVCHD clips? at DVinfo.net
AVCHD Format Discussion
Old February 3rd, 2011, 02:12 PM   #1
I'm doing an initial rough edit on about 25 hours of AVCHD material for a documentary. Initially I'm cutting clips using Smart Cutter by FameRing, and logging them into an Excel spreadsheet.
However the editors must use the resultant AVCHD clips, which SpeedEdit doesn't support.
What is the best way to batch transcode hundreds or thousands of AVCHD clips? I have Premiere Pro CS5 and various other video converter utilities.
Joe Marler is offline   Reply With Quote
Old February 3rd, 2011, 04:41 PM   #2
Cineform's NeoScene will do that.
Junior Pascual is offline   Reply With Quote
Old February 3rd, 2011, 06:44 PM   #3
Joe
You are trying to transcode AVCHD into what format??
It's not clear to me what you are trying to do exactly.
Bob
Old February 3rd, 2011, 06:58 PM   #4
Our main editors use SpeedEdit, which does not support native AVCHD editing.
I can quickly sub-clip the original material without reencoding, but those sub-clips must then be dragged into a timeline and edited.
After creating the AVCHD sub-clips (which stay in AVCHD format during that process) it appears I'll need to batch transcode them to AVI or some other format which SpeedEdit supports.
My question was what's the best utility and procedure for batch transcoding from AVCHD to (let's say) AVI?
Old February 4th, 2011, 02:19 AM   #5
I second Neoscene. You can get a good deal on it from Videoguys.com - CineForm NeoScene for PC and Mac
Six out of seven dwarves are not Happy
Ray Barber is offline   Reply With Quote
Old February 4th, 2011, 06:07 PM   #6
Absolutely
The Cineform HD avi codec is bulletproof & if your editors have the software to decode it, it should work fine.
I edit nearly all of my HD projects as CF regardless of the acquisition codec
Bob
Old February 5th, 2011, 03:00 AM   #7
in my usual workflow, i batch transcode AVCHD files to Avid DNxHD .mov files with Adobe Media Encoder. Works great.
Iker Riera is offline   Reply With Quote
Old February 5th, 2011, 09:25 AM   #8
Thanks everyone for the suggestions. The editors downstream from me have now upgraded their software to handle AVCHD directly.
If that doesn't work, after I clip out the rough cut (about 20% of the raw material), I'll transcode that smaller portion from AVCHD to AVI using Media Encoder, CineForm, etc. before passing it to them.
Old February 12th, 2011, 08:51 PM   #9
"MainConcept Reference"
is another great option
Justin Hewitt is offline   Reply With Quote
Old December 23rd, 2012, 07:04 PM   #10
Re: Batch transcode many AVCHD clips?
Just wanna help out, I have scripts, drag n drop EZEncoder, that will convert to prores for windows or most any other format you like all free, EZEncoder An awesome ffmpeg based encoder that does it all
Batch conversions by the folder...
Martin Smith is offline   Reply
