FCP warning at DVinfo.net
AVCHD Format Discussion
Old July 21st, 2010, 05:28 PM   #1
FCP warning
Hi. FCP refuses to encode about one in ten of my clips with the following warning.
" (folder name) contains unsupported media or has an invalid directory structure. Please choose a folder whose directory structure matches supported media."
I am dubbing over everything quite properly including all sub files etc. Is this happening to anyone else? Is there a work around?
MD
Mark Davis is offline   Reply With Quote
Old July 23rd, 2010, 05:12 PM   #2
You seem to be having extraordinary problems.
I've been using FCP with AVCHD for quite a while - some where in the region of 200-300 hours of footage imported so far - and only have this problem ONCE on a card that really was corrupted through user error.
So, yes there could be problems - but you need to look at your workflow and see if there could be anything else contributing to the problem.
Qualified UAV Pilot with CAA PFAW
Aerial Photo / Aerial Video | Corporate Video Production
Dave Partington is offline   Reply With Quote
Old August 11th, 2010, 07:27 AM   #3
Thanks for the answer Dave ... I completely missed the post. Things smoothed out. Still happens occasionally but bought Toast as a backup solution as it can take the .mts files directly when FCP won't. It produces good pro res files without any fuss. Having a lot of trouble using its other conversion formats though - AVCHD to DVPRO for example. The conversions are always distorted or banded. I've just posted another thread on it. Thanks again
