HDR-SR11 & Memory Stick Capacity at DVinfo.net
AVCHD Format Discussion
Old March 27th, 2010, 08:37 AM   #1
Does anyone know?-> What is the largest Memory Stick GB capacity I can use with my SR11?? I record live music events with my SR11 and sometimes VERY loud music crashes the Hard Drive(due to the HD shock protection feature). Therefore, for very loud performances, I use the memory stick. Right now I just have the 8GB MS Pro Duo. I know I can go with the 16GB but will the 32GB work?
Rick DeBari is offline   Reply With Quote
Old March 28th, 2010, 01:04 PM   #2
It's likely that a larger capacity MS Duo will work, as they are usually compatible, the only way to know for certain would be to try it, but your odds are good.
Old April 17th, 2010, 11:31 PM   #3
Just an FYI, you can replace the hard drive with an SSD drive. This will get rid of the sensor problem. Was thinking of doing this myself but decided to sell mine instead. Go to the AVS forums if your interested.
Randy Painter is offline   Reply With Quote
Old April 18th, 2010, 03:56 PM   #4
I just tried my Sony 32 gig and it worked. I have the 32 gig for my PSP.
EX3, Q6600 Quad core PC - Vista 64, Vegas 8.1 64bit, SR11 b-cam
Erik Phairas is offline   Reply
