avchd bit rates? at DVinfo.net
AVCHD Format Discussion
Old November 24th, 2009, 12:51 PM   #1
avchd bit rates?
1. Why do the bib companies advertise that 24mbt is the max when
2. Blue ray disc play at higher bitrates. I have a PS3 and the display shows the bitrate to sometimes be a high of above 45...
3. Why does the Canon DSLR shoot at a higher then 24 mbt bit rate.
If they say it's the maximum then shouldn't it be?
Craig Bellaire
www.VerticalVideoSolutions.com
Craig Bellaire is offline   Reply With Quote
Old November 24th, 2009, 02:19 PM   #2
What's a bib?
You are thinking of AVCHD bit rates.
Blu-Ray plays multiple media formats including MPG-2 and data streams.
Panasonic HMC150/Canon A1/JVC HD1/Sony Vegas 8.0c
Jeff Kellam is offline   Reply With Quote
Old November 24th, 2009, 08:32 PM   #3
24 Mbps is the maximum bit rate specified by the AVCHD spec which is a directory that contains H.264 video and audio streams. H.264 codec itself can have bit rates much higher than those used by the Canon video DSLR. Blu-ray spec has 40 Mbps maximum for all compatible video codecs, namely H.264, MPEG-2 and VC-1. Like AVCHD, any of these codecs has to reside in a fixed directory structure unique to the Blu-ray disc format.
Wacharapong Chiowanich is offline   Reply
