Can I edit AVCHD In FCP 5.0? at DVinfo.net
AVCHD Format Discussion
Old May 11th, 2009, 03:13 PM   #1
If not, how do I get the correct version?
James Collins is offline   Reply With Quote
Old May 11th, 2009, 03:30 PM   #2
No. I believe AVCHD support began with version 6.0.2. The latest version as of this posting is 6.0.5. You should update your FCP and your Quicktime. Believe it or not you are probably going to need to upgrade your iMovie as well (you'll be using that to import your files.).
"Get Er Done!!!"
G. Lee Gordon is offline   Reply With Quote
Old May 11th, 2009, 03:35 PM   #3
How do I update them?
Old May 11th, 2009, 03:40 PM   #4
I don't know if the jump from 5.0 to 6.0 is an update or if you have to buy a new version. But go here, it'll get you started:
Apple - Support - Final Cut Pro
"Get Er Done!!!"
