VoltaicHD
My SR11 will arrive this week. Even though I will own an HD camcorder , I'll be stuck in making SD DVD's since I don't have a blue ray burner, I found in the internet a cheap software that converts AVCHD to AVI. It's called VoltaicHD. Any comment about VoltaicHD?
Why not use the Sony software that comes with the SR11. It can make both AVCHD AND SD disc with menus or will convert the AVCHD file to mpg for authoring on other programs. You will also have to use this software to transfer the files from the SR11 to the PC anyway and will join the files of less than 4G into larger files on the PC ( the HDD in the SR11 is FAT32 so is limited to 4G files, if you record long programs it automatically creates 4G files which will need to be joined later).
Ron Evans |
I use VoltaicHD to convert my AVCHD files from my Panasonic SD9 into something that premiere will understand. Mind you I am running premiere 6.5!!!
Have tried pinnacle studio 12 ultimate, but its oh so slow with my duo core processor. Ross
Panasonic HDC-SD9 & Panasonic MX300 |
I've been using Toast 9. It's a lot quicker than VoltAICHD. Toast will convert the file in 2.5x real time, while VoltAIC took 10x-12x realtime.
#5 |
Guys, thank you for your input. When my camcorder will arrive I will try the sony software that comes with the SR11. If it's slow then I will try the Toast 9 ro VoltaicHD. But i could see the hassle because my computer is just Pentiom D 3.2 Ghz 3 Gigs of ram. Maybe it will take centuries to render AVCHD to AVi or Mpeg.
#6 |
Bo toast 9 is for the Mac :( anythign better on the windows platform would be niice.
Even better get one of these:- http://www.holdan.co.uk/blackmagicde...tensitypro.htm Ross
#7 | |
Ron Evans |
#8 |
Voltaic vs. Toast
I've heard that Toast doesn't make as high quality conversions as Voltaic. Anybody else have thoughts on that?
#9 |
i just got voltaichd ... yes conversion is a bit slow but i just convert 15 or so files at a time and walk away for a bit ... about 2 minutes time for a :10 clip ... converted files look real good in final cut or premiere ... worth the $35 for what i need it for...
#10 | |||
Your computer is barely passable to edit SD much less HD. And when you add the pain of AVCHD, I'll be surprised if it plays at all.
DVX100, PMW-EX1, Canon 550D, FigRig, Dell Octocore, Avid MC4/5, MB Looks, RedCineX, Matrox MX02 mini, GTech RAID, Edirol R-4, Senn. G2 Evo, Countryman, Moles and Lowels. |
#11 |
i only have 2 gigs of ram on my pc and i edit avchd files natively with vegas...a bit sluggish at times but workable...
on my mac (also 2gb ram) the converted avchd files with voltaichd are as smooth as basic sd files on final cut... |
#12 |
What Mac do you have? A G4? And what level of PC?
#13 |
macbook is an intel...2 yrs old...2 gb ram
pc is a 3 yr old hp...nothing out of the ordinary...2 gb ram |
