The Hitch USB to USB 2.0 xfer device - tested with HG10 Canon at DVinfo.net
AVCHD Format Discussion
Old December 11th, 2007, 08:58 AM   #1
http://www.gethitch.com/about/
USB 2.0 xfer device called The Hitch by Sima Products. ($99 @ Best Buy, ~$70 @ B&H).
I had some high hopes for the device.
Heading on vacation for 3 weeks, and was looking to bypass a laptop purchase (have very little need for one)..
I'm not sure how much video I will shoot, but it might be excessive.
So I figured I'd travel lighter and bring some 500 gb USB 2.0 external HD's.
First test - copy a small file from HG10 to a 2gb flash card. Could not transfer a 2 gb file to the card as there wasn't enough space. 300k file transfered fine.
Second test - I had 3 files on the HG10 at 2 gbs. Transfered them to the HD. 1st file was 20 minutes xfer. 3rd file finished in about 1 hour.
So that's 6 gb/hour xfer.
That seems respectable for a little device, but with 40 gb HD on the HG10 that turns out to be about 6.666 hours (6:40) for a full HG10 dump.
I'd suspect maybe a slower times if I had many files say 50 files to xfer.
Third test tonight -
What happens when the file names are the same and it is copied over.
Are they overwritten or will the Hitch rename them?
Brian W. Smith is offline   Reply With Quote
Old December 11th, 2007, 03:24 PM   #2
those numbers don't look that great - 8G Memory stick dump (one hour HD XP, best quality) from my CX7 takes 20 minutes - about 1/3 real time... fast file transfer is probably THE reason to transition from tape for certain uses.
Otherwise, tape has it's advantages...
Old December 11th, 2007, 04:31 PM   #3
Yep, not great.. consider the 3 files copied over to my PC in 1-2 minutes. (Did not actually time it).
