Do the Atomos Samurai Blade Recorders support Sandisk Ultra II SSDs?? at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Atomos Ninja / Samurai / Shogun
HD-SDI field recorders supporting a variety of codecs.
Old September 18th, 2015, 06:08 AM   #1
SanDisk Ultra II SSD 240GB specs - Info & Properties
As I want to get this. But it isn't on the list of approved drives:
Drives | Atomos
But Sandisk Ultra II SSDs are listed as recommended for Shogun / Ninja Assassin. I'm assuming they only have older SSDs listed for their older recorders as haven't tested newer drives with it, but from the specs, and because it works with Shogun, it should be able to work fine with the Atomos Samurai Blade? Is this correct?
David Peterson is offline   Reply With Quote
Old September 18th, 2015, 06:39 AM   #2
Re: Do the Atomos Samurai Blade Recorders support Sandisk Ultra II SSDs??
Yes, Atomos isn't updating the list for the Blade, but you can rest assured that anything that can work in the Shogun/Assassin will also be fine in the Blade.
Old September 18th, 2015, 10:01 AM   #3
Good to hear!
  You are here: DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Atomos Ninja / Samurai / Shogun
