Ninja 2 stops recordingwith Sony PMW-EX1R at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Atomos Ninja / Samurai / Shogun
HD-SDI field recorders supporting a variety of codecs.
Old June 9th, 2015, 10:24 PM   #1
*Problem: Ninja 2 stops recording on it's own or will jitter/break file or stop when slight panning of camera.
Camera: Sony PMW-EX1R. Not used very often. Have been using external monitor with no problems so HDMI port should be fine.
Recorder: Atomos Ninja 2 with latest firmware
Media: (2) Sandisk 480g Extreme Pro SSD's (approved model - brand new)
HDMI Cables: Short, good quality from B&H photo. Have tried several. Tight connections. Supported so not pulling on ports. No adapters/splitters, etc.
I have tried different combinations of settings and all cause problems. Sometimes the recording lasts lone (up to around 3 hours), sometimes 10 minutes. Camera on tripod. Only movement is occasional panning. Sometimes Ninja 2 just stops recording. Sometimes when I pan. Sometimes image jitters then it resumes with a new file. Some of these time the files need to be repaired.
Settings I've tried:
Sony Camera: - Timecode: Set to time of day. (not record run, but from what I've heard/tried this camera cannot trigger a start of the ninja anyway. Is this true???)
Ninja 2: - Timecode: Trigger: None/timecode / Timecode: Time of day
CODEC: Prores LT mostly but also tried Prores 422 and Prores 422 HQ
Video Settings (Note: The Ninja 2 only gave me 3 options):
Sony Camera: 1920HQ/30P (1080P with 30FPS, although through HDMI I believe it is 60i)
Ninja 2: 2:3 1080P / 1080i 5994 / 3:2 1080P 23.98 (greyed out/cannot select)
and
Sony Camera: 1920HQ/24P (1080P with 24FPS, although through HDMI I believe it is 60i)
All combinations have caused problems. Is the unit defective or is this an issue with my camera and the Ninja 2? Are there some other settings I need to set?
Thank you
Anthony Botta is offline   Reply With Quote
Old June 10th, 2015, 07:53 AM   #2
Re: Ninja 2 stops recordingwith Sony PMW-EX1R
Do you get a kangaroo icon or the recording just stops?
Old June 10th, 2015, 08:05 AM   #3
Sometimes I get that icon. sometimes not, But like I said, I do not shake or vibrate the camera/ninja so not sure why I get it at all.
I have ordered a replacement in case this one is defective. But I fear the new one will do the same thing and that it is a communication problem with my camera. I have not been able to find much information on the internet of anyone with this problem. I have found some similar posts but nothing that was helpful. If anyone has any ideas please let me know. Otherwise I will update when the replacement one arrives.
Old June 10th, 2015, 07:47 PM   #4
The EX1R's HDMI does not have HDMI timecode.
I think the EX1R's HDMI just sometimes has random compatibility issues. I know when I tried to plug directly into an Epson projector it just refused to show any signal.
Try with a SDI signal into a Connect S2H to see if the problem presists. I know sometimes the EX1R is very particular about what HDMI devices get picture.
Old June 10th, 2015, 09:48 PM   #5
Thanks for the advice. It would be nice to know that before I bought the ninja 2. If this is a known issue they should mention it in their camera compatibility list, and I think B&H Photo (where I bought it) should be aware. Unfortunately I was hoping to use it this weekend so I don't have time to get the converter. Plus it kind of stinks that after I spent almost $1,000 (on the ninja and accessories) that I have to spend another $300 to try a converter.
I am getting a replacement Ninja 2 tomorrow so I will test that but I figure it will do the same thing.
But I assume if this is an issue with the EX1R then probably any external HDMI recorder will have issues? I've been using an external monitor for a while with no issues. But I guess that is different than an external recorder.
Also I've been searching online for a while and although I've seen some ninja 2 posts with issues, I have not seem to come across anything explaining what is happening with me or mentioning anything about the EX1R having issues with an external recorder. Maybe I have to search harder.
Thank you for your response.
Old June 10th, 2015, 10:10 PM   #6
It's just been my personal experience. 99% of the time the HDMI detection on the EX1R will give the display/recorder a picture, but it takes a while (6-8 seconds if it chooses to be slow) and is picky to 1% of HDMI devices.
You should have 2:2 pulldown on for 1920/30p. The HDMI only outputs 60i. The SDI can be set to 1080 24psF, which the converter would turn into native 1080p progressive in 24p. In 30p, turn on 2:2 pulldown even if you're going through a converter.
Old June 11th, 2015, 09:47 AM   #7
Thank You. I should have the replacement ninja today. So I'll see if it performs any better. If not then i guess i wont use any backup for this weekend. But maybe after I'll look into a converter or just return the ninja and look into something else.
Old June 11th, 2015, 10:23 PM   #8
Well no good news. The new replacement Ninja 2 was totally defective. Screen just showed vertical lines. Couldn't do anything. I called Atomos and they agreed. They suggested I reinstall the firmware update to the old unit as that sometimes doesn't install properly. They said what I'm experiencing should not be happening.
I did that and it ran for an hour with no problems. I tried again a little later and after 10 minutes I did a quick pan and it stopped recording.
So I no longer trust Atomos. I will have to work without backup this weekend. And next week I will ship everything back to B&H. Very frustrating. Back to square one.
Old June 12th, 2015, 12:46 AM   #9
I've heard of a lot of issues with quality control with them, even with the highest end Shogun.
FWIW, the Blackmagic Hyperdeck Shuttle (soon to be supplemented with the Blackmagic Video Assist) is a safer bet right now. Personally, if I need broadcast compliant footage at or above 50mbps, I use a Nanoflash.
Old June 12th, 2015, 04:55 AM   #10
I was looking at the hyperdeck shuttle but did not like something wih no display where I couldn't tell how much recording time was left, etc. and when I looked up nanoflash it said it was discontinued.
I'm not really looking for something with better quality either. I like having the option of being able to record with better quality than my camera but for what i do my main goal is backup in case something goes wrong. I like having 2 copies of the footage. So maybe I'll look into a different manufacturer and one that connects via SDI instead of hdmi.
Thank you.
Old June 12th, 2015, 10:59 PM   #11
The Blackmagic Video Assist should do for you then. It's a 5'' 1080p monitor and a ProRes/DNxHD recorder that records to SDXC cards. Has both SDI and HDMI and can take in a maximum of 1080p60.
Old June 13th, 2015, 09:24 AM   #12
Oh that sounds pretty good. I'll have to take a look into that.
  You are here: DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Atomos Ninja / Samurai / Shogun
