My 3 Samurai Feature Requests at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Atomos Ninja / Samurai / Shogun
HD-SDI field recorders supporting a variety of codecs.
Old December 26th, 2012, 11:18 AM   #1
1. Working audio meters - switchable between 2 tracks and 8 tracks which display actual 0 db scale. Also put them on the record monitor picture screen.
2. Remaining media countdown. Put it on the record monitor picture screen.
3. Make the red recording bars flash when less than 2 minutes remain on recording media.
I think it's OK that the peaking, false color etc are on separate menu screens, but it would also be nice if some of those features could be readily accessed from the recording picture screen also, like to turn peaking off or on to check focus or false color for exposure.
Atomos, these features are vital for working professionals. You have done a remarkable job with these two recorders at a great price point compared to other manufacturers. However, these two simple features will be a great improvement to both devices by not forcing us to constantly switch from actual picture monitoring to menu screens while we are recording.
Anyone else with firmware improvement suggestions please chime in.
Old January 16th, 2013, 08:48 AM   #2
Re: My 3 Samurai Feature Requests
On a similar vein to the requests above I would ask that the battery level should be indicated on the monitor screen.
Just had a recording come to a sudden end because the batteries had expired and I then realised that you can't see the battery level on the monitor screen.
So that would be a very helpful addition.
Duncan Say is offline   Reply With Quote
Old January 16th, 2013, 01:02 PM   #3
Good additional suggestion. So far no response from Atomos team that monitors this board, but perhaps they are too busy implementing these firmware improvements . . .
Old April 13th, 2013, 04:30 AM   #4
Have they ever fixed the facial recognition focus problem? The only useful auto focus on the Sony A99 is the one where it tracks faces but the Ninja 2 maddeningly records the focus square around the faces. This means no meaningful steadicam shots.
Betsy Moore is offline   Reply With Quote
Old April 15th, 2013, 06:31 AM   #5
I think that is a problem of your camera not the recorder. The Ninja can only record what comes down the HDMI, and if you have overlays turned on then obviously it is going to record it.
You should get on to Sony and see if they will update their firmware if this is not something that you can do in camera.
Old April 15th, 2013, 11:46 AM   #6
Screen rotation. Since the Samurai has mounting holes on the top and the bottom it would be nice if I could mount it on my camera using the top mount hole (upside down with the screen rotated the right way.). That way, the BNC connections would be on the right side (where they are on my camera) and not on the left.
Don't know if this is currently possible or even if it makes any sense.
Jose Carlos is offline   Reply
  You are here: DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Atomos Ninja / Samurai / Shogun
