Do I need one .? at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Atomos Ninja / Samurai / Shogun
HD-SDI field recorders supporting a variety of codecs.
Old September 26th, 2012, 07:20 AM   #1
Do I need one .?
Hello bord, I have a ex camera , both SDI out and HDMI out, will the ninja help improve the detail and qlty of my footage. at the moment I just record to the stand sxs cards.
Rob.
www.rpbproductions.com
robert@rpbproductions.com
HD101/G5 Mac/4gig Ram/1TB HDD/30" Cinema Display/FCP.
Robert Bale is offline   Reply With Quote
Old September 26th, 2012, 08:36 AM   #2
Re: Do I need one .?
Hi Rob,
Consider that you are currently recording to Long-GOP MPEG-2 at 25 or 35Mbps using 4:2:0, and that Ninja/Samurai will record ProRes at 100, 150, or 220Mbps intra-frame with 4:2:2 color. You may not notice much difference at first to the naked eye, depending on footage. If it is very busy footage (lots of detail/motion) then the ProRes advantage will be more readily apparent. Differences will become more noticeable when color grading or compositing with ProRes footage, as you would see improved results.
Another benefit is extended record times for long events without the need to change camera cards. Plus you can edit direct from the Ninja drive if you want, without moving footage to computer drive first. Also provides a larger preview monitor than the on-camera LCD.
Jeff Pulera
Old September 26th, 2012, 09:26 AM   #3
An old blog of mine may be of interest:
Mike Marriage - Blog
www.mikemarriage.com
Mike Marriage is offline   Reply
  You are here: DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Atomos Ninja / Samurai / Shogun
