Samurai: deleting files? at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Atomos Ninja / Samurai / Shogun
HD-SDI field recorders supporting a variety of codecs.
Old May 31st, 2012, 12:56 AM   #1
Isn't it possible to delete any recorded video files within a Samurai unit?
Many thanks
Burkhard
Burkhard Scheibe is offline   Reply With Quote
Old May 31st, 2012, 11:16 AM   #2
Re: Samurai: deleting files?
Bud...as far as I know, you can't delete individual files on the Samurai. You have to 'Format' the drive to delete 'all' the files.
Regards,
J.
James Kuhn is offline   Reply With Quote
Old May 31st, 2012, 01:36 PM   #3
Bud...however, with ATOM-OS v. 3.0, you get "SmartLog - the ability to mark in and out points and tag clips using XML metadata...". This is directly from the ATOMOS AtomOS 3.0 NAB '2012 announcement. Essentially, you can choose the 'clips' you want to keep.
Regards,
J.
Old June 1st, 2012, 02:30 AM   #4
Thank you James!
Yes, I meant how I can get rid of certain video files using only the Samurai unit. Obviously this isn't possible.
Regards,
Burkhard
Old June 1st, 2012, 12:08 PM   #5
Burkhard...glad I could be of assistance.
Regards,
J.
Old June 4th, 2012, 08:00 PM   #6
Originally Posted by Burkhard Scheibe View Post
Thank you James!
Regards,
Burkhard
Yes I wish you could just hit a delete button to delete the last shot you recorded. Multiple BAD takes that have to be downloaded later is a waste of time and space.
Scott Imler is offline   Reply With Quote
Old June 4th, 2012, 11:30 PM   #7
Honestly, deleting any files on set is possibly one of the worst ideas ever proposed.
The potential for mistakes through human error is large. Even malicious deletion is possible.
But above that, you NEVER know what you might need or be able to salvage until you are in the edit. I've lost count of the number of scenes I've seen cleaned up with random cutaways and inserts taken from bad takes or just random rolls.
Seriously, don't delete anything, ever.
www.davidwilliams.com.au
David C. Williams is offline   Reply With Quote
Old June 5th, 2012, 10:58 AM   #8
David...yes, the ability to 'delete' the wrong file is an issue. Especially if you have a large production crew with a lot of 'hands-on' type people. There is a Locking feature now on the Samurai which helps to keep well meaning folks from screwing up.
Regards,
J.
  You are here: DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Atomos Ninja / Samurai / Shogun
