Help Needed with Atomos Samurai at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Atomos Ninja / Samurai / Shogun
HD-SDI field recorders supporting a variety of codecs.
Old March 12th, 2012, 10:12 AM   #1
Previously, I had been using the Atomos at 1080i with out a problem.
I am currently having issues recording 23.98 with the Samurai
F3=HQ 23.98 PsF
Atomos=3:2 23.98P ProRes HQ
If I set the F3 to 23.98 PsF it works fine, but I can't use the Zacuto EVF witch requires 1080i
When I set the F3 output to 59.94 (2-3) the EVF works, the Samurai detects the pulldown (monitor button lights) but I get a nasty studder with interlacing.
I was under the impression that the Atomos was supposed to detect and remove the 3:2 pulldown.
Am I totally missing the point here? Can anyone give me any suggestions?
Chuck Fishbein is offline   Reply With Quote
Old March 12th, 2012, 10:52 AM   #2
Re: Help Needed with Atomos Samurai
Camera set to 23.98 HDMI output 60i
Samurai connected to SDI A
Zacuto to HDMI out
Douglas Villalba - director/cinematographer/editor
Miami, Florida, USA - www.DVtvPRODUCTIONS.com
Douglas Villalba is offline   Reply With Quote
Old March 12th, 2012, 11:36 AM   #3
"Samurai connected to SDI A"'
Ah... As opposed to the plain SDI out?
Old March 12th, 2012, 11:40 AM   #4
SDI Out & HDMI carry the same signal with pulldown added. Recorder goes to SDI A.
Old March 12th, 2012, 12:22 PM   #5
By the way, whomever moved this thread should know that this is an F3 thread problem. It is not a recorder problem but a connection to the F3 problem.
Old March 12th, 2012, 12:31 PM   #6
Thanks Douglas,
I'll try that right now.
Old March 12th, 2012, 12:47 PM   #7
Ok, it's working. Again my thanks
And for the benefit of those going through this for the first time:
At first it didn't work when I switched on the dual channel SDI out (for channel A) but then I noticed that the menu no longer said (SDI/HDMI) on/off, it now just said (HD HDMI) on/off . Once I changed that it appears they're all working, and no pull-down is indicated on the Samurai.
  You are here: DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Atomos Ninja / Samurai / Shogun
