#46 |
Re: ATOMOS Subforum?
All the cables are stored under the items in the case.
You can see one of the mini SDI cables coming out of the Samurai on the second photo. The full-size SDI connector is a receiver plug, so you don't need a barrel connector to link it with a standard full-size BNC cable. |
#47 |
You get two mini-SDI to mini-SDI cables in the case.
#48 |
Peter,
So I can be 100% certain about the included cables, can you clairfy something? There are 2 cables (very short) and these are mini BNC on both ends? I obviously have a full sized BNC connector on my camera and I need to know exactly what I will need when my Samurai arrives. I have no SDI or BNC cables currently, so I am trying to make sure I have what I need, no surprises. I looked at your photo closely and the cable seems pretty short so I am guessing that I will need a coupler along with another standard bnc cable perhaps? I wish the PDF file on the Samurai stated or showed the exact cables so that I would not have to bug you! Thanks for any insight you have. |
#49 |
This is the part that is confusing me. Why they include mini-sdi to mini-sdi when I am unaware of any cameras that have mini-sdi ports on them to start with.....or I lead a very sheltered life! As my previous post was asking, I just want to clarify this because it seems odd is this is accurate.
#50 |
For those of you concerned about the cables in the Samurai box, here they are. The Samurai has mini-BNC connectors.
2 x mini-SDI to SDI 1 x Firewire 800 1 x USB 1 x USB Power to use with USB blue cable (if required) |
#51 | |
#52 |
Sorry, no idea for sure James. However, I suspect that if there's a problem with a component in one location that is probably going to be the same in other locations and thus affect worldwide distribution. D
#53 |
Peter,
Any initial impressions? How's the screen resolution? Does it just record what the camera is putting out or can you convert by changing the record settings in the Samurai? Thanks!
www.elkinseye.com |
#54 |
I haven't been able to test much becasue I'm flat out on edits. It appears to just record the output resolution/frame rate of the camera as received from the SDI. The screen rez and colour is okay, but becasue it is touch-screen technology it doesn't come close to the sharpness of my TV Logic 056. But I wasn't expecting it to. One worrying point is the mount spigot appears to be M6 metric and not imperial 1/4", so I haven't been able to mount it to anything I own.
#55 |
Screw thread size sounds odd! How did you get it onto the F3 in your photo? I can't imagine they changed it from the Ninja, as the basic bodies are identical. Maybe that's part of the delay? D
#56 |
that is a bizarre thread size. you may need something like this: http://www.noga.com/nogaProducts.php?prdID=AD6010 also is there a way to power it via a d tap or do you have to use the batteries? how long do the batteries power the unit for?
#57 |
I could just screw it in a little to take the photo, but it wasn't stable enough to shoot with. I hope to hear from Atomos this week about it.
#58 | |
#59 |
Hey Peter...you can get a 'prize' from TapeWorks Texas, Inc., a 'supporter' of DVinfo, if you show them you've actually received an Atomos 'Samurai'. I think it's kind of a 'bounty'. Heh, heh!
Give it a shot and get back with the group. J. |
#60 |
I'll send them an email. Cheers!
