Atom ninja or not - Page 2 at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Atomos Ninja / Samurai / Shogun
HD-SDI field recorders supporting a variety of codecs.
Old August 15th, 2011, 10:55 AM   #16
Re: Atom ninja or not
Bill, that is unbelievable footage at your link. I can see now what you guys are talking about.
Old August 15th, 2011, 01:25 PM   #17
Originally Posted by Ric Marrty View Post
Yes but is it 10 bit 4.2.2.?
No one seems quite sure what's coming out through HDMI, but if you run the AVSynth code, for sure you'll get 4:2:0 sampling.
Old August 15th, 2011, 08:17 PM   #18
Looks good but whats the work flow using the avsynth?
Will avsynth work with another hdmi recorder like mini matrox or motu?
ric
Ric Marrty is offline   Reply With Quote
Old August 15th, 2011, 09:28 PM   #19
Yes, any HDMI capture system will work with AVSynth. The Marvel blog has a semi easy work flow that's download ready.
Probably the best thing though is what for GH2 hackers to get it up and running, they're breaking new ground every hour and may have already cracked hdmi out, lot of excitement over the GH2 hack right now and Vitaliy even has a special strike team of coders working specifically on the HDMI out.
Old August 16th, 2011, 05:00 AM   #20
You may also find Jorgen Escher's step-by-step workflow instructions useful: GH2 HDMI AviSynth No Hassle Quick Start Archive Jorgen Escher
Also see Jorgen's update here based on Ralph B's latest: GH2 HDMI AviSynth No Hassle Quick Start Archive Jorgen Escher
And here is why HDMI recording is better than the hack: Why hacking the GH2 does not make a better camera. HDMI recording still superior. Jorgen Escher
Hope this is useful
Bill
Hybrid Camera Revolution
Bill Bruner is offline   Reply With Quote
Old August 16th, 2011, 09:14 AM   #21
Thanks for the info . But what I don't understand is :
1- Install the avsynth and just capture and the avsynth will do its thing automatcally
2- Do I have to do some tweeking in avsynth after capturing.
Do you think matrox mini is a good alternative?
thanks again
Ric
Old August 16th, 2011, 09:17 AM   #22
Jorgen says:
"It’s a bit simplistic to think that you can upgrade a camera’s quality by just raising the codec’s bitrate; you’ll need to upgrade the limiting factors along the processing line all down to the sensor."
What's so simplistic????? this theory transformed the GH1, and is doing the same for the GH2.
The hack is currently working out an incamera HDMI hack that will eliminate the need to run to a 3rd party software like AVs.
Old August 17th, 2011, 10:40 AM   #23
avsynth and audio
Could processing through avsynth affect audio? specialy if using using dual eyes?
ric
  You are here: DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Atomos Ninja / Samurai / Shogun
